Hey all,
I was cruising throught the Prestige Motorsport stock and came up with thisToyota Aristo. They run a twin turbo six, but not the wimpy 1JZ like the chaser - they get the full 2JZGTE treatment! *Insert Fast n Furious quotes about engine here*
Compliance is still about 8 months away apparently, but I think 4-Door Skyline and Stagea owners better look out - family man in a hurry has a new weapon!
The crazy part is that one on Prestige is for sale for LESS THAN $11,000!!!!
Maybe I should upgrade my R32 4-door for one. I was considering the UZZ31 Toyota Soarer and R34 Nissan Skyline Sedan as an upgrade, but I think the Aristo has joined the list!
What do people reckon?
https://www.sau.com.au/forums/topic/95291-toyota-aristo/
I wouldn't take an 11k example as the 'average'.
I emailed Geoff and he said that yes, this one is particularly cheap. Typically the Aristos start at around $13k, which is still a bargain in my mind! :angry:
prestige always does that
You say that like it's a bad thing! Surely advertising cheap cars on the Prestige website should be encouraged not looked down upon :P
I got some additional information:
Twin turbo JZS147 2JZ-GTE 3lt 206KW/1680kg IL6 Engine -122kw/tonne.
Non turbo JZS147 2JZ-GE 3lt 169kW/1580kg IL6 Engine - 107kw/tonne.
4WD UZS143 1UZ-FE4ltr 191 kW/1740kg V8 Engine -109kw/tonne
Sunroof and Leather are uncommon options, and ALL were sold as automatics. The only manuals are aftermarket jobbies.
https://www.sau.com.au/forums/topic/95291-toyota-aristo/#findComment-1724551
Well i don't know, they just seem to pick a couple out there which are that lower price to 'bait' people, then when people ring because of the low price, that car has been snapped up 'but wait, we have more we can get access to'.
It's a standard business practice, but you know :P
Edited by predator2
https://www.sau.com.au/forums/topic/95291-toyota-aristo/#findComment-1724561
chris, that's the newer aristo, the one everyone likes... the one in the first post is the old one... mechanically/technologially cool, but a bit lacking cosmetically.
https://www.sau.com.au/forums/topic/95291-toyota-aristo/#findComment-1725520
Gueses on what youd get the v300 for? yeh the lexus 2jzgte
my "man the jza80 is nice but it sure looks bling bling" worries are over. Im saving right now for this.
http://www.lexusvertex.com/aristov300_spec.htm
still prolly handles like a whale and is slow oof the line but it would make a great freeway cruiser.
Edited by Boostzor
https://www.sau.com.au/forums/topic/95291-toyota-aristo/#findComment-1726938
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
