hi all
i crashed my r32 gtr 6months ago up to now just been fixed, wasn"t a major crash front end,replaced radiator,intercooler,condenser,light bar etc crash neva got to engine
the thing is after it got fix, it wasnt as fast as b4 feel like a non turbo
the car was sitting there for 6month W/O driving after i had the crash
what could be wrong?
ECU need tune?
i have n,t got it service yet since the crash? could that the problem
I aslo notice the oil pressure guage sometime read at zero when driving and idle.
pls help
thx all
Edited by Godzil_R
https://www.sau.com.au/forums/topic/95301-r32gtr-not-as-fast-after-crash/
Very hard to say could be alot of things,
Like any power loss problem check boost and fuel and timing.
Maybe the intercooler piping is leaking somewhere?
Is the fuel fresh in the tank? It does go off after a while.
It should not need a retune they dont just fall out of tune sitting there.
good luck
i put it on the dyno today show the engine was running on 5 cylinder and was pretty lean, that explain the approx 80hp power lose.
they told me first replace spark plug to fix the mis.
If this does not fix the problem it either fuel pump or injector block or fuel rail.
well i hope it just the sparkies
anyone know what spark plug to recommend on r32gtr?
pls post ur recommendation
thx all
a thread i readed b4, sumone had the same problem,engine feel restricted,shyt of shake when accelerated, it was sign of misfire eg.coil pack or sparkies.
The thing i wanna know is a guy post these commend below
is it safe to do what he stated?
"to find out which cylinder it is, unplug the coil pack while the car is on... If ur idle drops then that cylinder is fine... If there is no change in idle u know u found the problem one."
yeah exactly how you should do it.
or use a consult cable and turn them off 1 by 1 via the software.
other missfire reasons could be dirty afms, cracked coil packs or ignitor dying. you really just need to swap things 1 by 1
i mainly concerned about the mis or spark problem that causing the engine to run on 5 cyclinder or 1 of the cyclinder just damage due to car havent been driven in 6 month.
so do u guy think is the mis that cause engine to run on 5 cyclinder, coz engine was in great condition b4 crash nothing was wrong, crashed neva affected engine so why is it after fixing the problem like these arised.
were did the engine sit after the crash and how bad was the crash was it still driveable?
crash neva touch the engine i only fix from front to radiator that it
after crashes it set their 6months while i was chasing parts, wasn't drivable cos intercooler n radiator was wrecked
Edited by Godzil_R
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
