Be careful putting the timing belt back on. Make sure you put the tensioner back on properly.
It may have been just a bizarre coincidence, but two people I know changed their water pump on rb30s. They were sure they did everything right but a few months later the tensioner for the timing belt popped off. Ended up with bent valves etc.
Just a word of warning.
https://www.sau.com.au/forums/topic/95313-water-pump-vl/#findComment-1726711
I kinda lied.
One was my car, I just didn't wanna seem like a dodgy mechanic. :blink:
But I am sure I did everything right. I don't know what went wrong. Happened about 4 months later and bent the valves. Mechanic said he has heard that it is common for them to come off for no reason, but its strange it happened after both had the timing belt removed.
In my mates 31 he didn't bother to fix it, just wrecked it. Thats where I got my series 3 front for my car. :P
So he might not have bent valves. That was just an assumption.
https://www.sau.com.au/forums/topic/95313-water-pump-vl/#findComment-1727183
Yeah make sure that you get all the seals and gasket done properlly. If there is one certain week point with a VL, is it's cooling. Water pumps common problem. Just make sure that baby's (for lack of a better phrase) water tight.
And yeah be extra vigilant when putting the timing belt back on. (speaking from experience) :(
Sava.
https://www.sau.com.au/forums/topic/95313-water-pump-vl/#findComment-1727754
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
