drifty_jnr Posted November 17, 2005 Share Posted November 17, 2005 Hey guys just thought i throw a query your way.... it's happened to 3 r32 skylines i know of.. symptoms... No leaks fluid is full pump and belt are good.. it cuts in and out and feels like there is no power steering at all... i've driven a couple of r32's and the steering compared to mine feels like i dont have powersteering at all...... just wanna pick some brains before we go on a search and destroy mission... cheeers ben Link to comment https://www.sau.com.au/forums/topic/95327-r32-power-steering-troubles/ Share on other sites More sharing options...
Chris32 Posted November 17, 2005 Share Posted November 17, 2005 Happend to mine a while ago Swapped pumps and still was stuffed Then I jacked up the front, with the engine off, and turned the wheels both ways as far as it could go about 5 times each way. This supposedly gets rid of any air in the system It didn't seem to help much, maybe a touch lighter, then a day or so later it was back to normal To this day I have no idea what caused it Link to comment https://www.sau.com.au/forums/topic/95327-r32-power-steering-troubles/#findComment-1725812 Share on other sites More sharing options...
Bl4cK32 Posted November 17, 2005 Share Posted November 17, 2005 I replaced all ps lines, new fliud (bled the system as chris said), even fitted the tomei hicas lock black box (it stopped the light coming on the dash, but i havent fitted shims yet) and the power steering still goes heavy from time to time...its starting to piss me off big time... Link to comment https://www.sau.com.au/forums/topic/95327-r32-power-steering-troubles/#findComment-1725824 Share on other sites More sharing options...
Josh Posted November 18, 2005 Share Posted November 18, 2005 You don't have a leak at the rear? with the HICAS?? Link to comment https://www.sau.com.au/forums/topic/95327-r32-power-steering-troubles/#findComment-1726012 Share on other sites More sharing options...
blind_elk Posted November 18, 2005 Share Posted November 18, 2005 How old is your battery? (Skylines are notorious for their sensitivity to voltages and charge rates). Check the connections onto the alternator. And maybe the plugs on the HICAS computer. Link to comment https://www.sau.com.au/forums/topic/95327-r32-power-steering-troubles/#findComment-1726697 Share on other sites More sharing options...
