R33A31 Posted November 18, 2005 Share Posted November 18, 2005 I'm new with Nissan, hope some 1 can advise on modification sequence. Before this Nissan I'm play with Mitsubishi Evo 2 & modified as per www.dsm.org sequence & manage to achive 380 Hp till stage 3. What about R33 RB25det ? Link to comment https://www.sau.com.au/forums/topic/95363-r33-modification/ Share on other sites More sharing options...
paulr33 Posted November 18, 2005 Share Posted November 18, 2005 injectors (stockers run out of capcity around 200-230rwkw, 550cc minimum) airflow meter (stocker runs out of capacity around 220rwkw, z32 or q45 afm) tyres (stock or crappy tyres will just result in lots of wheelspin) suspension (standard suspenion will hamper your launch capabilities) brakes (stock calipers should be ok, but you should look at some good rotors and / or braided brake lines and good pads) ecu (stock ecu will be useless. go for aftermarket stand alone. recommend apexi powerfc) fuel pump (stock pump will run out of capacity around 200rwkw) intercooler (stock intercooler will run out of capacity around 180rwkw) exhaust (stock exhaust will be useless, at least 3.5" dump pipe / front pipe and 3.5" exhaust with hiflow cat) boost controller (good a good bleed valve or electronic controller) pineapple kit (to prevent axle tramp) standard plenum is fine (no need to change) here's a base line list, you just need a suitable turbo. hiflow of the standard unit should get you to 250rwkw easily without any extra lag. once you go past that stage you need to look at internals and consider how much money you really have and what your target is. Link to comment https://www.sau.com.au/forums/topic/95363-r33-modification/#findComment-1725956 Share on other sites More sharing options...
R33A31 Posted November 18, 2005 Author Share Posted November 18, 2005 I have Greedy TD06 20G laying around from my Evo3 engine but the the exhaust housing changed to 7cm hsg. Any idea how to change back to bolt on to my RB25det exh. manifold. Link to comment https://www.sau.com.au/forums/topic/95363-r33-modification/#findComment-1725985 Share on other sites More sharing options...
R33A31 Posted November 18, 2005 Author Share Posted November 18, 2005 Can I use the stock injector from my Evo3 (6x510) to this RB25det ? Link to comment https://www.sau.com.au/forums/topic/95363-r33-modification/#findComment-1726003 Share on other sites More sharing options...
R31Nismoid Posted November 18, 2005 Share Posted November 18, 2005 Please read the sticky in this section. http://www.skylinesaustralia.com/forums/in...showtopic=66556 and no, you cant use evo injectors Link to comment https://www.sau.com.au/forums/topic/95363-r33-modification/#findComment-1726072 Share on other sites More sharing options...
