I'm seriously considering throwing some $$$ into my car.
Been doing a LOT of reading, and i've pretty much settled on this list of goodies.
Car at the moment has stock ECU and stock turbo/cooler, as in sig.
Engine appears to be healthy, it's just clicked over 100,000 and had all belts/pump replaced etc etc.
1) Z32 AFM ~$250-300 2nd hand
or $400 new Nengun
2) Genuine Hybrid FMIC with piping $800 autospeedbits.com.au (delivered)
or $700 no-name with piping justjap.com (delivered)
3) Apexi Power FC $950 group buy SAU
or $1050 Racespec
or $954 Nengun
4) Injectors SARD 550+ Collars $930 nengun
or Nismo 550 $890 nengun
5) Turbo GCG Hiflow $2000 [EDIT: now HKS GT-RS]
6) Beefy Fuel Pump *tick* Mk4 supra
7) Heavy duty clutch *tick*
?? 8) Fuel pressure reg eg $150 Nismo nengun
TOTAL $4050 + ?injectors + labour/tune
--> $5000-6000 complete, give or take a bit.
Bearing in mind i would be installing the PFC and FMIC myself, and then probably get it trailered to a shop with a turbo and injectors and get them to make it go :)
I want a bolt-on turbo without too much fussing around and i thought the GCG would be a good way to go for cost and ease of fitting.
a few questions for those that have done this before...
a) Will i need injectors? it seems that i will.
b ) Will i need a fuel pressure regulator?
c) Rough power - is 240rwkw reasonable or would 220rwkw be more likely?
and finally,
d) Would it be better to source parts and get them in, or get a shop to sort parts for me? I've heard so much conflicting information. I'm not set on getting "rice" name parts; they are just what came up on a quick price hunt for initial costing.
If i've left stuff out i'll try and add it in.
Thanks for your ideas/opinions/criticisms,
B
Edited by Beeble
https://www.sau.com.au/forums/topic/95367-opinions-please/
Im not in anyways experienced, but I dont think you'd require a Nismo fuel pressure regulator along with the injectors. Spend the cash and go injectors.
Also, search ebay for great condition 2ndhand 'name' brand intercoolers direct from Japan. Or a GTR cooler for $500 local with custom pipekit (again can buy a box of pipes off ebay and cut them to suit your application).
Sounds good though - I had a budget of 10k over 2yrs for my Stagea, already spent over 6k in 4 months! :)
Brendan
https://www.sau.com.au/forums/topic/95367-opinions-please/#findComment-1726032
Yep. If you're short on cash then a fuel pressure regulator will be enough to get you to 240rwkw but with enough money you might as well save the hassle and just go straight for the injectors.
Aftermarker injectors will be far more than enough for 240rwkw which you should be able to get with this setup :blink:
https://www.sau.com.au/forums/topic/95367-opinions-please/#findComment-1726889
Thanks for the replies guys.
Yeah i've got mods both sides of the engine, and have the stopping/handling side of things fairly well sorted aswell.
Been thinking of getting some bolt-ons for the engine for a while now, and i finally (read: a few years!) feel i know the car's limits well enough to strap on some extra kilowatts :blink:
Never ordered through Nengun before, but through a similar site (Taka Kaira). I'd be expecting 2 weeks or so for delivery?
https://www.sau.com.au/forums/topic/95367-opinions-please/#findComment-1727020
please read the sticky
http://www.skylinesaustralia.com/forums/in...showtopic=66556
mod order/suggestion threads are all covered in there.
only reason ill leave this open is you've given specific detail re: pricing and so forth.
here are some answeers for ya.
a) Injectors, dont need a reg, stock one is fine
B) Refer a)
c) 250rwkw, Bass Junky did with his GCG, but slightly different to normal one but around that you'll make, more than 220
d) PFC - get from nengun/greenline. Get a NEW Z32 AFM. 2nd hand ones cn be dodge and not worth the hassle
https://www.sau.com.au/forums/topic/95367-opinions-please/#findComment-1727098
go for 740cc's as they are like $5 extra per injector from nengun.
and get nismo instead of sard no need for collar crap
make sure you have 3" split dump and 3" hiflow cat
and some good tyres as well. good cold air intake dont leave the pod unshielded
https://www.sau.com.au/forums/topic/95367-opinions-please/#findComment-1727633
Okay after much reading and research and conversation i've decided on the HKS GT-RS. Good resale and i've read nothing but good reports.
Nengun has a package with PowerFC + 740cc Injectors + turbo kit, which i know a few people on SAU have installed in their cars already, with good results.
My concern is re: injector size.
I'm consistently getting told 550cc is plently for my needs. Having the overhead with the 740cc ones is fine, but a few shops have mentioned that the idle will be better with the 550cc ones.
The co$t between the two sizes is negligible
Does anyone have the 740cc injectors running, or know someone that does. any problems? This will be a daily driver battling peak hour traffic regularly so it is concerning :(
I've read every injector thread i could find and this issue is never mentioned. (maybe it's not much of an issue??)
I'm looking at getting this done in the next month(s) and will be sure to post dyno results etc for anyone else considering this path.
Cheers guys
Edited by Beeble
https://www.sau.com.au/forums/topic/95367-opinions-please/#findComment-1732183
I had them running in my car for over 8 months.
No problem what so ever
- direct fitting
- drove peak hour every day for about 4 months during that time also.
- idle was no different to stock (using a PowerFC)
You think the GT-RS isnt a bit of overkill for you though?
the GCG item is exceptionally nice and would be better suited IMO
https://www.sau.com.au/forums/topic/95367-opinions-please/#findComment-1732267
^^Thanks, good to know.
I'm aiming for 250rwkw. Looking at track days and some advanced driver training with the car once it's all sorted.
GCG hiflow rb25det's seem to vary from 220(base)-260(with cams)rwkw from what i've seen, whereas GT-RS cars seem to be consistently pulling around 240-250, higher with cams.
I have a feeling i'd be a little disappointed with 220 if that's what i ended up with, is all.
Price difference is about $600 all up, with a stock turbo to sell/play footy with. Resale value comes into it too - IMHO the HKS will come out on top when it comes time to sell the car.
Edited by Beeble
https://www.sau.com.au/forums/topic/95367-opinions-please/#findComment-1732324
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
