My '96 Skyline (R33 GTS-T) has a misfiring problem. After spirited driving, the engine misfires while idling. It's bad enough that gf and I go "WTF!" when we both cop what feels like a boot in the ass while waiting at the lights. I'm not sure why it does it, but after reading on here, I suspect a split in the coilpacks that might be causing the spark to arc out and hence miss.
Now here's what I consider the "real" problem:
I bought the car about a month ago, and this misfire is the only thing that really bugs me about it. I rang up the warranty company and they said all work on the car must be done with their approval and by a mechanic they nominate, after being inspected by one of those mechanics to confirm there is a problem.
The companies they listed are Fast and Furious, Evo Motorsports and some guys called "Layton Automotive".
Now, when I was shopping for the car in the first place, I got a less than great impression of FnF, and after reading the "where to get ur skyline serviced" thread, I am VERY hesitant to take it to EVO for even an inspection, never mind any work done. They also didn't impress me too much during shopping, same as FnF. So I rang Laytons, who basically said "you're much better ringing up Evo... they have much better resources for working on ur car than we do."
After all the horror stories I've read and heard about Evo, I'm not sure I want to take the car there at all... this isn't a HUGE problem.. but it does bug me.. but if i take it to Evo and they screw up the car even more then I'll be kicking myself because it was only a small annoyance in the first place.. I don't want them to work on it and leave other stuff broken or whatever, and increase my troubles.
What do u guys think I should do? The thought of just getting the coilpacks swapped out by someone like Ed@Integra Automotive or another third party has crossed my mind.. and to just not say anything to the warranty place at all.. I mean, can anyone imagine in the future some major 5h1t happens with the car and needs a few grand work and they look inside the bay and go "Woah there buddy, hang on. Those aren't the stock coilpacks!" (or whatever they determine is the cause of my problems). I mean, the car is secondhand anyway! They wouldn't have a clue what was in the car on the day I bought it.. There's no big changes like aftermarket turbo etc.. just exhaust and wheels and slight lowering.
Anyway, tell me what you think, as I really do want to get rid of this minor niggle, and would rather pay someone I think is trustworthy (i.e. anyone that's been recommended in the previously mentioned thread) to just fix the problem and not mention it to the warranty place. :) Think I'll go ring Ed or someone now and see what they think.
https://www.sau.com.au/forums/topic/95377-argh-warranty-issues/
Take it to Ed at Integra. From what I have seen, these warranties are practically useless and a waste of money.
Before you do anything, chuck another set of spark plugs in it. Its a 30 minute job, and the plugs (BCPR6ES) will cost you about $15 - $30 depending where you get them from. Could just be a set of shite plugs that are cleaning themselves up when driving hard and foul straight away again at idle/low revs.
Like always I will recommend Trojan in Mitchell. Plugs leads and coil packs sound like the place to start looking. It depends on how good the warranty is but it might be worth doing if it saves you some cash? F&F is a workshop that doesn’t really have a reputation and is trying desperately to get one. They are closely associated with J Racing and have even moved to be closer to them. To be honest I would go of my gut feeling if I had the choice. If you didn’t get a good vibe from F&F then don’t go there! Pay the cash yourself and check out Trojan. A workshop who’s reputation allows them to have never advertised or even put a sign up outside the shop! lol…In contrast the F&F are always on the radio/print with there ads.
my personal opion is to if you can pull coil packs off one at a time to find the one causing the issue, then if you have no luck swap ignighters with someone, the reason i say to do this is to save you some money, and to find what ther real proplem is, then go see a real work shop, eg ED's or Trojan
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
