Need Advice Whats Next? R32gts-t Mod Question
Well that rules out the relocation theory, however with no load, you're still getting 1.5bar of oil pressure. Can you present that data in a scatter graph over longer period? Would really highly the anomalies. Wish Haltech could do that. -
I also understand psi but apparently most things make more sense in kpa oil pressure being one of a few exceptions so im trying to learn ahahahah, I have no idea of the relief spring pressure tbh I thought 110 which is the absolute peak it hits was about right, I was thinking of removing the relief and making sure it is in good condition, I would just replace it but couldn't find a replacement for an n1 pump too easily but I could just be blind.
It certainly does make sense that there is just no oil to pick up, but I can go 3 or 4 gears of WOT and have no oil pressure issues too (I have no logs of this unfortunately) and I have a fair amount of oiling mods to try and help only thing I'm missing is a rear head drain which is potentially the most helpful.
speaking of the relief spring and noting this is one of those stupid times where I understand imperial (psi) but the graph is in metric (kpa), it looks like the oil pressure is a little low at full noise too, isn't the relief spring 120psi/830kpa?
No. All these dirty old Datsuns are shitboxes. Including the GTR.
