Yo, just hoping to get some opinions/advice about the microtech ecu's on RB20/25 engines (especially the LTX12 series) as it seems hard to get any info here in NZ & i see a lot of the Aussie guys are running them.
If you are running one what are your thoughts on it? what are they like at driving big injectors (550cc on an RB20) do they have closed loop & does it equal the factory's system? are they easy to tune?
& i heard the LTX12 can be purchased with an adaptor loom to plug into an R32 RB20DET loom, does anyone know if this is true?
Cheers, appreciate all your feedback. good or bad
https://www.sau.com.au/forums/topic/95401-micotech-ecu-on-rb-series-engines/
I wouldnt say  "a lot fo aussie guys"
I only know of one person with a sky using a microtech
What does your tuner over there prefer?
Hmm i thought the 2 most common ecu's for skylines in OZ were Microtech & power FC?
Tuner is trying to sway me to just get the standard ecu chipped but i am possibly looking at adding other things later on so an aftermarket management system is looking like the only option. & the only two that are in my price range are Microtech LTX12 & power FC but i have had an extremly hard time trying to get hold of the RB20 type so it is almost out of the question.\
Your thoughts on the microtech?
Microtech's are built to a price they do fuel and timing and thats about it. The LTX12 has a few extra options idle control and an addtional output its all on the website I think. You only need to take a look at timing control in a static conditon to apprciate how shit the timing control is. As for idle control actually not to bad considering. Closed loop - kiss that good bye.
The biggest problem is the variation of MAP signal - you can use a pill to damp this off but in the end its still shit. I am bias because the main aim of where I work is tuning standard ECU's but we also tune microtech, xede, PFC, haltech , motec and autronic. You will actually gain more torque across the board with the standard ECU as it has better timing control. ie the standard ECU is 1deg sensitive as is PFC whereas a microtech is about 3deg sensitive. You just cant go past the PFC or Chip IMO. (Hmmm prepare for the flamming)
If your tuner wants to go with a chip go down that road and get it retune later chances are there wont be that much to do.
Microtech is ok, im running one in mine (LT8) it does just enough of what i need, albeit no Cold start IAA etc... but still starts fine.
if i had my way again and had the cash i would definatelly go with a PFC, enough said....
nothing wrong with a Dribbletech.
they all have pretty good resolution with the 3dtuning software. and they can be configured to read all of the factory sensors.
im not sur about closed loop.
at the end of the day it comes down to how well its tuned. fullstop.
microtech web site
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
