i changed my spark plugs today, i just got it all back together and started it up, and it sounds off...sounds like a boxer engine???
i made sure everything went back in the right places, all plugs put back together, so can anyone help me out here?
feels like its restricted too, not as much acceleration, it feels like theres a shyte load of torque as the whole car shakes when i accelerate...can someone help pleeeeeeeeeease??
its an R32 GTS-4 RB20DET
thanks guys
https://www.sau.com.au/forums/topic/95418-help-please/
Dude one of ur plugs isnt firing.....check everything is tight again, coz thats the definate answer. Had the same problem once and my leed popped off, open ur engine bay, taek ur coild packs off or leads and check the plugs again, then make sure ur coil packs are back on tight.
https://www.sau.com.au/forums/topic/95418-help-please/#findComment-1727070
yeah im going to check it all tomorrow it will definately be one of the above, a coil pack not joined properly, a dead plug possibly or even a vaccum hose that i missed, but i have my money on the coil not makin a good connection...shall post tomorrow, hopefully with a solution
thanks again guys
https://www.sau.com.au/forums/topic/95418-help-please/#findComment-1727652
yeah guys, just as everyone suspected, the first coil pack had become loose when i was putting it all back together, pluged her back in, now my straight 6 sounds like a straight 6 again....yay :P thanks for the help guys
https://www.sau.com.au/forums/topic/95418-help-please/#findComment-1728585
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
