:P Have R32 GTR. When I'm cruising with no boost, usually on freeways, I'm finding that when I accelerate to pass a truck or car etc. the car seems to slip, like the clutch slipping. The revs go up, then it grips and the revs go down.
So here's my delemma, why when I thrash the living hell out of it on 1.1 bar is there is no slipping????????
I have a triple plate clutch. Could heat in clutch be making it grip; or heat in Attessa system making traction work though the front wheels?
I have not changed the attessa automatic fluid for longer than I remember (IN fact never since i got it from Jap, bad hey, didn't know it was there till now. Done all other things). Can revs be lost in attessa system, sending torque to front wheels???
Any ideas anyone.....
https://www.sau.com.au/forums/topic/95432-attessa-or-clutch/
mine does that some times when i turn sharp corners that go up hill, i hear the wheels slip and the attessa needle goes up, and the car seems to bog down. But when i'm playing i don't realy notice the car bog down when the rears slip.
btw you stole my handle :P
what does the front torque gauge show when this occurs?
if it was loss of traction then it should bounce up a little when attessa transfers power to the front. but it sounds like clutch slip if its going up and then down a little.
This slipping that's accuring is not accuring under any harsh acceleration. It happens after being at the same revs for a while, usually while crusing on the freeway. Then when half throttle is applyed thats when it happens. There is no loss in traction because there isn't enough power.
Thats the reason i don't think it is the clutch. It usually doesn't happen a second time for a bit, till i cruise again and after 3 mins or so.
dude, i been around longer than u, savman is mine :( nah, my last name is savage, hence savman.
You could have 1kw and if the clutch is stuffed it will do what you are describing. Its something in the driveline between the engine and wheels thats slipping (hence the engine speed going faster than the car actually is), and the only real part in there that can cause these symptoms is a clutch.
If your clutch is wearing out, you will notice it slipping in 4th and 5th gear first. When mine was on the way out, it took about 3 months of driving around with 4th and 5th slipping for it to start slipping in 2nd and 3rd.
Exactly, it sounds like clutch. ATTESSA won't allow what you are describing, as the rear tailshaft is constantly driven via the gearbox regarless of what ATTESSA tells the front wheels to do. The only variable is the percentage of front drive governed by ATTESSA. So if she aint wheelspinning, the clutch is slipping!
:) Have R32 GTR. When I'm cruising with no boost, usually on freeways, I'm finding that when I accelerate to pass a truck or car etc. the car seems to slip, like the clutch slipping. The revs go up, then it grips and the revs go down.
The ATTESSA system can be disabled by pulling a fuse. Symptons of its failure are that there is little or no torque transfer forward - despite what the gauge is telling you. Mostly this will give you bulk oversteer - you should be able to feel the front wheels pulling the car back into line if the system is fully operational.
Unless you have a serious lack of rear end grip you won't be getting wheelspin in third or even fourth in a straight line. Which suggests clutch. To allay you fears about the ATTESSA system, get a mate to drive alonside & keep a lookout for wheelspin.
Just as a side note - I had my car feel like it was slipping once and it was a basic ATTESSA problem. The the boot of the GT-R's on the drivers side there is a little bottle inside a small compartment. That was below the minimum level line. I topped it up with ATF and the problem was solved. No harm in looking into that 1st.
I just had that yesterday. For about the last week, whenever I started my car from work (and only work - weird, perhaps coz I park in the sun and things were getting hot? Dunno...) my 4wd light would come on and wouldn't go off unless I turned the car off and re-started. I was at a driving arvo yesterday, and when i went out on the track I noticed that around all the corners my front torque guage was on 0 (it is only a sprint track, but still), and under acceleration the guage wasn't showing what it normally did. That whole run the car felt like a rwd.
Luckily I had stopped and bought some ATF (I got genuine nissan, just incase it was a special blend) on the way, topped up the reserviour in the boot as it was about 2 inches below the minimum line. Next run felt a little bit better and the run after that it seemed to be back to normal. The min and max lines are only 1cm apart though which seems a little....silly!
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
