Thank you for yet another informative answer there dezz.
As krzysiu said. FM is generally decent transmition but it's no where near as good as a digital transmition or direct conection. So you will never get as good quality which is unfortunate cause i also enjoy just listening to the radio a fair bit.
FM radio is about 2/3 of the quality of normal cd audio. The first thing you lose is the depth of the bass when you transmit in this manner. Basically the transmission leaves out bits.
All you have to do is increase the bass on your eq or whatever you use for that. Some head units can have different settings for radio and cd.
I was about to suggest that... all the head units i've come across require you to set the bass/mid/treble for radio and CD independantly.
Funnily enough, i've always found radio to be bassier than CD's!! The new HU in my Skyline is the same... just like my last car. Weird!
I think you will find its a bit like mp3, just more so. Mp3 compresses the data you cant hear, or your stereo cant produce. Radio is the same, just they keep going in to what you can here.
Technically mp3 still isnt as good as a cd, but it all comes down to the orginal recording anyway, and how good the system is at reproducing the sound.
JTS25T: Dunno man... my new Kenwood does it, and my old Kenwood in my Commodore did it. Kinda handy, cause FM radio has always been more bassier to me. (not as bad as AM radio though)
If FM radio is Frequency-Modulated, and high-pitch is in the upper range, and bass is in the lower... maybe the upper is being cut out a bit by the radio stations?
Also listening to music on air is free, and hence music quailty is also low!! Wont be your typical 128kbs..
Also since the waves travel further, the frequencies may also decrease in quailty.. not 2 sure on that..
  • 4 weeks later...
something that i remember from uni in regards to wireless transmission.
sound (music) is a whole spectrum of frequencies. bass is the lower range frequencies, treble is high.
Frequency modulation (or AM for that matter) allows transmission of this spectrum of frequencies over a single frequency (ie what you tune your radio to).
However to transmit the whole spectrum requires infinite power (not possible) so a compromise takes place. Hence why FM doesn't sound as good as CD.
radio is up to 22khz range, whereas CD is 44khz.. which allows much more frequencies to be accurately transmitted in the spectrum. Usually that would mean that its the higher frequencies that you'd lose, so I guess there must be other explanations why you lose bass frequency... probably to do with bass requiring more power to send the lower wavelengths long distances??
Radio plays crap usually repeditive music anyhow :mellow:
They were talking about digital radio which would improve the quality, but they've been talking about that for 10 years and not much has advanced in that area.
I think some head units will try to recreate some of the bass lost in radio transmissions, which is why some headunits make the radio bassier than others... My alpine is a lot bassier on the radio than a cd, but so much so that it sounds like crap.
I also know, that all the Brisbane radio stations are shit too... especially the new morning crew on all B105, Triple M and Nova... All of them like to share with you every morning how ignorant they are and how cool it is to be a dumbshit...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
