I have these 17" Momo rims for sale. Very uniquie and rare rims. I have
never seen these rims anywhere before, I don't even know the style lol.
Came with the car when I bought it. Reason for selling is upgrading to 19's.
Suit 5 stud Nissans. Not sure of the width but the tyres are.
235/45/17 (Suava Intensas) on the rears and
215/40/17 (Dunlop 3000gt) on the front
+35 offset
Came off my s14a 200sx without any spacers and no rubbing what so ever.
1 front and 1 rear brand new.
The other two need replacing, down to the indicators (camber wear).
Gutter rash on two of the rims (1 front and 1 back), but any rim repairer
could fix these for a small amount, not very noticeable.
Prefer S.A buyers but will send interstate if the buyer organises it.
$1000 O.N.O
No silly offers.
Let me know if you want to see more pics on a diff angle etc.
https://www.sau.com.au/forums/topic/95485-17-momo-rims/
  • 3 weeks later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
