i was wondering which one is best. I found out that stock mount ARC cooler will give more power than a front mount 600...300...76 HYBRID cooler..Is it true?
How come such a small cooler provide more power than a front mount.?.
Edited by rajja
https://www.sau.com.au/forums/topic/95512-front-mount-and-stock-mount-cooler/
the arc cooler is much better consuction and argued as one the best on the market than the hybrid and has better flow charactoristics and as it mounts in the stock location and same lengh pipeing as opposed to the front mount which will have more piping , the main difference is that you will have slightly better throttle response with one in the same location, as there is less volume the air needs to fill before the intake.
i run a d1 drift fmic kit and i think it is quite good, and i didnt really notice and lag or less respone thought i am not running stock boost and i was running 11 psi in stock cooler and once a changed it seemed a lot less restrictive, not sure what i would be like with stock boost though.
the end of the day i feel that the fmic will cool better as opposed to a cooler on an angle and it is harder for it to pass though.
it alll depends what sor of boost and power you would like to obtain.
hope i have been helpful
i read a write up on a silvia running a rb26dett probably seen it but it was running at 26psi through one of those puppies :P
i wasn't going to upgrade my cooler to a front mount coz i got a autospoiler (r31) and the size i would fit in there wouldnt be worth it but i think ill throw one of those arc smic ones on
Edited by Space Goat
26psi through a standard side mount cooler? great idea.
i think the stock cooler isn't too bad i just think the location doesn't make it as efficient as the other stock based intercoolers. i think you had an r34 or arc smic core on the front it would be quite nice and wouldnt have as much volume as a 600x300 core
i think he meant the ARC one. i was looking at getting one for my 180 but was a bit out of budget... but according to the seller they can handle 27psi.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
