Hey
I got in my car yesterday and went to go the airport and the car basically had no brakes. You have to put the pedal flat to the floor for it to even begin to start to stop. I can hear the pads etc.. closing and i can hear the master cylinder pumping. The ABS light is not on. Fluid was really low so i filled it up but that dident make a difference.
Any ideas ? The car is a R32 GTR.
Thanks
https://www.sau.com.au/forums/topic/95516-lost-my-brakes/
you probably let air get into the lines if the fluid went low enough. Or your master cylinder is f**ked.
Re-bleed the brakes and see if that helps, if that doesn't fix it, you may need to reco your master cylinder.
I'm assuming you checked the obvious. i.e. checked lines for brake fluid leaking etc.....
https://www.sau.com.au/forums/topic/95516-lost-my-brakes/#findComment-1729052
One of the mechanics said he could smell it leaking (we checked it at night) but it was really low so it might have got air in the lines.
https://www.sau.com.au/forums/topic/95516-lost-my-brakes/#findComment-1729071
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
