hey Guys,
I have started cleaning up the wiring on my car and found the knock sensors weren't even hooked up. Now my car runs a Haltech ecu but i still would of thought it would need these to run, can anyone shed some light on this for me (esp where the sensor wire plud is suppose to connect to)
https://www.sau.com.au/forums/topic/95529-knock-sensors/
Look down the back of the engine on the drivers side close to the inlet runners.
And on further searching have found that they do not incorporate closed loop knock sensor control.
Future reference....www.google.com.au
Type - Does Haltech use knock sensors
Google is your friend.
Edited by 3lit3 32
https://www.sau.com.au/forums/topic/95529-knock-sensors/#findComment-1729265
Well maybe....
In the end if the tune is safe, you use good fuel all the time, your injectors are clean, your fuel pump is in good condition etc etc.
With skylines a standard ECU is the only computer that uses the knock sensor as input, it moves to a "safe" map when it detects knock.
PFC comes up with a knock "number" based on the sensor but does not use it in the tune. If it is knocking its up to the driver to back off.
AFAIK no other aftermarket computer uses an rb knock sensor
https://www.sau.com.au/forums/topic/95529-knock-sensors/#findComment-1730107
  • 4 weeks later...
The Link ECU has a system where if the knock is too high, it will reduce the boost level until the knock is reduced. The Link ECU uses the factory boost controller to control boost up to 14psi.. COuld be more, not sure though.
https://www.sau.com.au/forums/topic/95529-knock-sensors/#findComment-1799902
bit of a question on this one...
assuming i'm using a stock ECU, is there any way to monitor knock?
I've got one of the Nissan Datascan units that Impakt (off these forums) makes that gives a readout of all the ECU parameters... the only one that it doesn't give that could be helpful is the knock readout....
any ideas?
https://www.sau.com.au/forums/topic/95529-knock-sensors/#findComment-1800147
ok I have found turboXS make a knock light and shift light all in one ($180 approx) (look in the current autosalon mag) Unfortunatly every supplier for turboxs I have tried haven't even heard about them let alone stock them
https://www.sau.com.au/forums/topic/95529-knock-sensors/#findComment-1802668
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
