  • Replies 248
ok the nite out stuff first
A bit of home handy man work on the Lada
The rest are here
http://www.pbase.com/joelstrick/afterhrs
Will post the action up in next few days
haha good times, good times!!
Hey Joel, it's asking for a password to view the pics, what is it??
I'm dying to see the rest of the picks!
Dane
So sorry guys in the hurry to get them up i forgot to add password its a hardone
sau
Cheers
What a weekend!
Big thanks to all for this event, I have been away for a while and had been considering selling the Skyline and keeping the Celsior and have decided i am not that old yet...... sell the Celsior and mod the 'line some more.
Wish i could have made it to the after party but had to have a quiet one with the family.
Really enjoyed letting rip for the first time in my car........... cheesy grins appear from nowhere when i think back
Hey Joel you got any pics of the silent assasin?  Haven't seen one so far. :P
Still  :) i made top 10 with a stock fwd.
I got some.
I kept missing them because I couldn't hear your car coming :P
What a weekend!
good too see ya back in the action Danny :P
been a good year since we all saw you last at the very least!
you certainly let rip too, good viewing :P
Cool pics Joel
Road Runner - Looking through the times, yours were fantastic. Any tips :P
Only tips i have is don't hit any cones and get lost in the maze. and push as hard as you can and still have fun. Also a quick car can help. :P
Cool! B)
I opted for the dont hit any cones theory especially on the wangs. That was the only way I was ever going to get a decent time. I think I hit one on the skid pan but hoped the quicker guys would hit a few more than they did :P
I did however get lost more than once which definately did not help :(
Am very impressed with the times set though by the GTi B)
A huge thank you to all that organized and ran the day. Was my 1st time at Deca and had a ball ripping up the skidpan before my car decided to run on 5 cyl :P
Dark etc etc if you could send the hi-res pics of my car (black R33 with cf rear diffuser - No 16) to [email protected] it would be much appreciated
Cheers :P
Cheers :P
Will do ASAP.
I was wondering why your car sounded like the rexies :(
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
