R34 GTR rims are 18x8 +30 offset from memory. They should sit nicely in a GTT. I've seen a few GTTs running around with GTR wheels. If you are looking at fitting 18s on the GTT, anything at the front with offsets +40, +35 should fit assuming they are 18x8s. You will also need to check on front brake caliper clearance. I have tried two sets of +
35 offset on my fronts before one did not clear because it did not have high disk clearance. Jap wheels can be very tricky in this respect. Best advice is try before you buy...which can be hard when you are importing or buying second hand. I've learnt this the hard way :)
34 GTR wheels are 18X9 not 18X8. you may have some trouble with the fronts, but i'm not entirely sure. best way to find out is to see if you can try a pair on. With some low profile 235s on the front they will probably be ok.
This is such a great forum and many experts opinion. Question is how is the alignment setting and whether the handling is effected compare with the stock standard rims or other after market rims? The design looks great and had offers for a set atm. One last question, if I change the GTT fenders to the GTR ones while still retaining the stock GTT bumpers & bonnet, will there be gaps during fittings? The GTR fender do balance the car up with the GTR rims and will not hit the inside while turning. The GTR bumpers are pretty low for everyday driving.
Thanks in advance for the pros....Cheers!
Sorry my bad...18x9 :P
i have seen a 33 gtst with them in japan ( with stock 245x45x18 tyres) and i have a picture but not 100% sure if they will hit , probably hit the front inner guards . If you want to see the pic p.m. me your email and i will send it to you .
Just to confirm , they are 18x9 and +30 offset .
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
