would have come over Dan, but i just woke up lol and off to work in about 1.5 hours. so wouldn't have enough time to get over there and back home before work.
more than likely be heading over there tomorrow if i can wake up in time lol :P let me know if your gonna be there.
  • Replies 215
Posted Images
Your a bludger... I just got home... Man that was a long day!
I have to work until about 2pm... then will head to the work shop for an hour or 2. Got to leave to get to Oran Park by about 4:30pm as I will be judging tomorrow night at the Driftland Masters... And then hitting the cans... much deserved this week I think!
UPDATE 23-03-06:
Well today has been a bugger... infact this whole week has been. Have really only spent about 10 to 12 solid hours on the car, and to be honest they have been interupted a fair bit... either way there is no way the new engine is going in and being run in and tuned before the 4th... maybe drop the old one back in and see where we come up.
I have about 1/4 of the whole car prepped... I will be putting a big effort in this Saturday to get it done and my phone WILL BE OFF.
R33Deviate, I spoke to a few people and Sand pblasting is a real pain in the arse... and apparently much more time consuming... and you still have to manually sand the tricky bits anyway... The biggest problem is that Sand blasting apparently causes denting that needs to be pannelbeat back out again... there is a new process using wallnut shells that is supposed to be less troublesome... but hey... I'm getting there and will probably onle spend 24 hours preping a pretty dirty car... so it is up to you.
Bring on tomorrow... just can't wait for my alarm to go off tomorrow at 4am.
Night all.
Thanks heaps Dan for the FYI on sand blasting! I have heard the same thing from my investigating, so i think the old elbow grease is the way to go.
More worried about getting the Cefiro to the track..... May... MAYBE :)
Ando
Edited by R33Deviat
Hi Ando,
I have all but done the inside, which has taken about 15 hours. So really, apart from the sore arm... it is the eaiser way to go in my opinion.
I will be starting and hopefully finishing the outside sometime today or early tomorrow morning... should be a solid 12 hour session today, starting about midday after I finish work. And then it is Paintin time!!! :D
Dan.
Might be a bit late with this but sand blasting to abrasive but plastic bead blasting is the way to go on automotive bits or cars . I had the sleeper on my truck done years ago and it was to smooth had to rough up the surface b4 i painted it .Bit late to let you know but worth storing in the ole memory banks for future referance
Cheers Peter
No idea....
But planning to paint the car next week... finally! I had no idea how long it takes to prep a car for painting.
And then put it back together... first track shakedown will be at Oran Park on the 29th of April.
ando, on the sand blasting it would not be a good idea to sandblast stuff in the open anyway. sandblasting is usually performed inside a sealed container (your hands go in through the glove thingys like homer wears in the simpsons). if you did it in the open the sand (grit) would go farking everywhere and you dont want to be breathing it or just having it all over the garage/workshop. with this in mind it's not really practical to sandblast a whole car. plus it would just strip the paint off, it wont give you smooth panels. for that my friend you need to shape the panel by hand. using sand paper (of various grits) and body filler.
sounds like it's cominly along dan. keep at it :)
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
