Well a good weekend... lots of positives, the extra power is helping, and the set up is coming along.
Smashed the front bar to bits on Saturday during Team Drift... never mind...
Sunday saw me up agains Kelly McKinnon, It was pretty tight first battle, but unfortunatly my handbrake got stuck on in the second battle and I spun... real bugger as I certainly had a chance... guess that is being chucked in the bin this week and replaced with a proper drift hand brake...
Team drift was fun, although a big smash saw the session canned after only one run.
Can't wait for Eastern creek at the end of next month... new turbo and a whole lot more incoming... stay tuned!
Dan.
  • Replies 215
Posted Images
Nice one Kinks!!! Post up some pics when you get it.
Richard, end of next month... as it says in the last line of the post... but more specifically in case that was what you meant... 29th and 30th of July.
See you all then!
Oh, and thanks for getting my AFR around the right way... I hate going by memory.
The Bel Motorsports sticker is on the wrong way around to be JDMyo
they are supposed to go from the front to the back of the vehicle...
But that is unless you are like Kelly McKinnon who thinks the other way
around is more aggressive looking... Anyway, take it or leave it.
If you look at this truck in my carpark you can see the way it works
with Chinese/Katakana characters... The letters are the correct way
around but go from the front to the back of the truck.
Anyway, congratulations on the results, keep up the good work!
Well development is coming along rather well... now have 224rwkw at a low 0.9bar of boost and at around 155kms in 4th gear. we also made 712nm at 70kms in 4th, and averaged 644nm across the entire rev range!
Which probably explains why I have no 4th gear syncro left. and 3rd gear is spitting out sometimes... I knew it would break eventually... but I was hoping for a little later in the season!
I have 2 dyno graphs, but I'll scan them tomorrow, or next week.
See you all at Eastern Creek the weekend after next!
Cheers,
Dan.
lol... you guys are vultures!!!
If I buy a new box the old one is being kept as a spare, looks like we will be buying a second handy for this round, and rebuilding the old one a bit stronger... especially as we are looking for more power still too!
If I look to sell it Nathan I'll give you a bell. (pm)
Dan.
Did I show you the new Pipe work and Catch can that RoadRunner Fabrications made up for me? Very Pretty!!!
Cooler Pipes
Catch Can
And also someone asked a while back about dyno graphs... I finally remembered to get them... and they are below.
First is Power,224RWKW @ 12psi (0.9bar). We did another run with 20psi (1.3bar) and only made 227rwkw... so it is time for a bigger huffer... BRING IT ON.
Second is torque... again same settings as above, in fact same run! Max 712NM, Min 497NM, AVERAGE across the run was 644NM
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
