hey guys,
i've had this problem with my 32 for quiet some time now and it's beginning to shat me Basically, when cruising, all is fine and no sign of smoke through the rear vision mirror. However, if i put my foot down and ramp up to top end, once i begin to slow down, a massive cloud of white smoke follows It certainly smells like oil so im thinking it's burning oil. Why? I've replaced the turbo but no advancement..
I read up on here somewhere that it could be related to the PCV valve? I know for a fact that when driving hard, the dipstick pop's out and covers my engine bay with oil? I've taped it down so that's no drama atm..
Has anybody had similar problems or suggestions as to how i should go about rectfying it? As for the car, it's an rb20 R32 gtst with fmic, exhaust etc;
Thanks in advance,
nuR
https://www.sau.com.au/forums/topic/95606-steaming-32/
If youre popping out the dipstick you have a fair bit of blow by, which points to shagged rings.
Under boost the pcv valve closes anyway, i doubt it's your problem. The big question is, how much oil is in the intake pipes?
https://www.sau.com.au/forums/topic/95606-steaming-32/#findComment-1730432
just wanna say that i've fixed the problem and it nothing to do with a rebuild :) It was simply a hose which was being blocked off..As for the distick, the rubber seal wasn't sealing which was causing it to blow off..All is good now :D
Edited by nuR.spec
https://www.sau.com.au/forums/topic/95606-steaming-32/#findComment-1736749
just wanna say that i've fixed the problem and it nothing to do with a rebuild :D It was simply a hose which was being blocked off..As for the distick, the rubber seal wasn't sealing which was causing it to blow off..All is good now :(
And that is exactly why you should seek professional advice from mechanics before taking further steps from information received here.
https://www.sau.com.au/forums/topic/95606-steaming-32/#findComment-1736889
Maybe you should edit your previous post in this thread.........
Why?
I was merely stating that as much as it is hard to diagnose faults at the best of times when you have the car in front of you, it is even harder to diagnose faults with limited information and hundreds of possibilities with no method of testing from where I sit. That is why it is important, no matter what anybody says on these forums, that you take your car to a professional for accurate diagnosis.
I still resolve to say that there is an underlying problem still as the dipstick should not pop out under the circumstances that he has described.
https://www.sau.com.au/forums/topic/95606-steaming-32/#findComment-1739009
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
