Heres some more how to videos
How to crash a skyline
http://www.hgeconsulting.com.au/targa04.wmv
How to crash a daewoo
http://www.hgeconsulting.com.au/woocrash.wmv
How to run in your new z
http://www.hgeconsulting.com.au/khanazed.wmv
How to destroy the tyres that are meant to last 3 days racing (starts at 3m16s)
http://www.clutchfcukers.com/videos/Dutton...ame.is.FATZ.wmv
fark me that wrx one is gold, so many great moments it's hard to single one out...
Tosh and I both agree that the two highlights are
"Dont worry about the evo mate you just keep on the track"
and of course...
"What about the brakes russ.....ooh the brakes russ"
"jeese that silver wrx has some poke in a straight line"
Yeah thats because it knows about a 4 letter word called an APEX!!!!!!!!
Also was that "4 wheel drift" or front wheels understeer
Duncan I sent you an email of me doing a reverse open wheel burnout in a KE55 corolla.....would you be able to host it ?
its in quicktime format though...
http://www.hgeconsulting.com.au/openwheelburnout.mov
hahha how to do a burnout eh?
I love the use of reverse for that bit of extra torque
bloody hoon!
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
