Hey Crew,
ive got an RB20 BB turbo on an SR20DET motor its had a few mods-
larger intake housing (4mm) and
larger V-Comp wheel to suit.
Im about to purchace an RB version of the disco potato which has an A/R of .64
I want the turbo to be as responsive as possible and i believe the A/R of the RB20DET is around .50
I guess my question is how much lagier will .64 be in comparison to .50
I can retain the .50 housing if i wish but im not sure it will reach 300HP at the wheels
The car currently makes 216HP on 15PSI
Looking to run more boost that why i want the Steel wheeled Diso Potato
Any assistance much appreciated
yes thats the closest guess we can make .48... and it will not flow anywhere near enough...
I guess you are buying the RB 20 version because you have a t3 style manifold?
because the SR version is cheaper and there is nothing wrong with the standard SR manifold... you will be able to put out 300 with the SR manifold and a disco...
Also they spool great!!! have been in 2 cars with them.
Yeah ive got a manifold which has a T3 foot, Morrie is now doing an RB disco turb which has the .64 housing. going the RB route will just save me all the extra costs of having to convert back to SR stuff IE manifold oil lines, new plumbing etc.
I have been told that the RB20 exhaust housing can just scrape it into the 300's so long as it has a rear steel wheel and plenty boost..
I like reeee sponse.
ive gotta get myself a ride in a .64 SR
honestly you will be forcing so much boost thru your engine you will be risking head gaskets. dont do the rb20 housing you will regret it.
the gt28rs is a perfect turbo for a sr20. trust me you woll be happy with it.
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
