Just got a 96 GTR and my mechanic has recomended first point for upgrade to wack a 3.5'' exhaust right through.
Wondering what is Legal and How do I find out what the legal limits are in QLD.
Also he rekons it will add about 40 rwkw , does anyone have any experience with this ??
regards sb..
https://www.sau.com.au/forums/topic/95652-r33-gtr-exhaust-upgrade/
The problems you will have is with the car being to low due to the exhaust going under the diff/drive shafts ect, the police will love to defect you for this, and also the biggest problem you will have is noise. 92 DB is the legal limit, i have a 3" exhaust right through and without the silencer i'm 102db @ 5100rpm. You should gain a fair bit of power from those mods, when doing this also get a set of pod filters or get a good pannel filter, something less restrictive. You should be able to up the boost to 1 bar and should be making around the 200awkw mark. Mine has the following done and is making a tad bit more power than that.
96gtrman i made my own 3.5' system with with twin 3' down pipes into 3.5' straight throught two the rear where at the time i could not buy the muffler(s) i wanted so as a tempary measure i cut the back off the standard unit gutted it and fitted the 3.5' into rear with the twin 2.5' standard tail pipes, the result was quiet awesome since then i have made 530rwhp with the system and i great a number of comments on the note of the gtr which is not really that loud so cruising isnt a problem/or police but it still has a nasty angry note. I used all mandal bends and also made custom 3' one piece dumps(like what tomei sell)
pete
ps if you take your time fitting it you can have it hang at the same height as std the diff is not a problem
Edited by pnblight
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
