question at hand is what are the standard rb cranks made out of?
cast? forged? chizzled out by some japanese sweatshop worker forced to gind them with nothing but bits of rocks?
trying to figure this out as there is a current war building over this topic on one of the stateside rb related forums.....
https://www.sau.com.au/forums/topic/95663-rb-series-cranks/
They are steel sorry, I dont believe they are forged, I guess it depends on your process of forging and the different understading of it??? Is there any way to prove a theory either way, be interesting to know. Forged for me means heated metal pressed into a shape???
I have a snapped rb20 crank and the metal is a little pourass like you see on something that is cast, infact the look of it looks like die cast thats the texture for those who understand, maybe that was due to the way it broke??? Now that I think about it I dont really know why I thought it was iron maybe cause it looks cast, momentary brain failure i guess, haha!!!
https://www.sau.com.au/forums/topic/95663-rb-series-cranks/#findComment-1731399
definative answer from mr science, a friend of mine that is a scientist but also likes nissans. As Greg said, they are forged mild steel, temper toughened (hardened), then machined and nitrided.
https://www.sau.com.au/forums/topic/95663-rb-series-cranks/#findComment-1733685
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
