I have driven my s13 with a rb26dett conversion for a while now and the compression has started to go down due to high pressure from the garret gt35/40.
At this time writing, I am planning a rebuild so I can use the full potensial of the turbo and possibly make 680-700 flywheel hp.
It would have been great if you could help me with the engine spec.
My plans so far:
boring and honing of block
polished and balanced crank
hks forged pistons 1mm oversize
nismo n1 oilpump
nismo rod and main bearings
jun headstuds
hks 1,6mm headgasket
tomei rod bolts
tomei oil gallery orifice
I also plan to shotpeen my original rods and maybe get them polished afterwords.
Is there anyone who can tell me how this is done?
Anyone who does this for a reasoable amount of money?
Do I need anything else to make the bottom end reliable?
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/
boring and honing of block DECK THE BLOCK AND THE HEAD ALSO (to help the metal head gasket seal)
polished and balanced crank IS YOUR RB CRANK R32 IF SO YOU WILL NEED TO FIX THE OIL PUMP DRIVE JUN CRANK COLLAR
hks forged pistons 1mm oversize or CP MAKE GREAT PISTONS USA
nismo n1 oilpump FOR THE BHP I WOULD CONCIDER A JUN OIL PUMP(especially if you plan to rev it hard)
nismo rod and main bearings NISMO THE BEST
jun headstuds
hks 1,6mm headgasket YOU ARE NOT CONCERN WITH RESPONCE BY RUNNING A THINK HG YES?
tomei rod bolts I WOULD BUY RODS ie PAUTER IN USA OR TOMEI/HKS ALL GOOD
YOU HAVE NOT MENTIONED THE HEAD SPECS what did you plan to run as bhp is basically pistons up?
pete
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1731458
jun headstuds
pete
thanks for the comments Pete!
Yes, i will deck head and block aswell.
It,s a r33 engine so dont need to do any changes with the oil pump drive?
I see that the jun pump is ALOT more expensive than nismo,
will try to keep i under 7800rpm so I hope the nismo is good enough.
for the headgasket, is 1,2 mm thick enough for my application?
Isnt the original shotpeened rods good for around 700bhp?
The head has been profesionally ported,gasfloved, and rebuildt.(also the combutioncamber)
any more help would be great!
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1733604
Yeah 1.2m head gasket will be fine
The std rods will take alot but 700bhp would be the limit and after such an $$ rebuild it would be a shame to lose a leg out the side(i got my pauter forged rods for $1500AUD deliveried)
The N1 oil pump is not NISMO and is the same as std, bare a stronger pressure relief spring and if your not going over 8000rpm will be fine.
What cams are you running and have you bought adjustable cam wheels for them?
What will the primary purpose of the car be?
pete
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1733957
ditch the jun headstuds and rod bolts and fit some arp bits.
http://www.paceparts.com/index.asp?PageAct...S&Category=7740 sells the head studs at a very reasonable price but you will proly have to look around for the arp rod bolts (tomei use arp bolts).
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1739752
Thanks for the good info guys!!
I will use arp bolts now.
The cams I am using is the tomei 260 type b with adj pulleys.
What are the recomended adjustments of the pulleys?
Or do I have to adjust them on a dyno?
The car will be used as a street car mainly.
And it will also be used at tracks and maybe some 1/4 miles :P
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1743005
What are the recomended adjustments of the Tomei pulleys?
Do you adjust them on a dyno?
Or when the engine is out?
dyno is the best place as you can see the direct effect of any changes and every motor is a little different. But i have found a little advance on inlet gives better and earlier low down power and some motors responced to a little exhaust advance as well. Best to test all changes on the dyno and you need to remember to reset timing when adjusting the exhaust timing.
pete
https://www.sau.com.au/forums/topic/95664-rb26-rebuild/#findComment-1751048
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
