purchased some sound sytem stuff recently...but don't have the intention to fit into my car as yet...holiday coming, thinking go down the track....
just wondering...I've seen those promoters in autosalon hang their subs on the wall, connected....hehehe..maybe, I should try connect the system in my room? since it's doing nothing atm...~~ wanted to get sealed battry...but it'll go flat real soon...how do I connect car audio to a power plug??
thanks~~
https://www.sau.com.au/forums/topic/95676-car-audio-in-my-room/
i had my sub running of my home theater setup, make sure the amp is capable of running the ohms the sub would be putting out and make sure its low passed and you shoule be right, i had mine running 4ohm per coil off 2 channels of a household amp with the sub feed from my theater receiver :D works a treat...
otherwise, you can buy power converters from jaycar that will run a full stereo system, head unit amps and speakers for about 250-300ish i think from memory...
what you can do is use an old computer power supply :) should run everything pretty well, I wasn't exactly running a stereo off it, but had a VHF hooked up to it and it worked a treat for me :D
(then again you might need some bigger amperes not 100% sure what comes out of PC power supply)
that could work but i think the pc power supplies are around 4A mark, so it should run a headunit fine, but an amp will probably draw 20A+, even more maybe...
This is the baby you can get from jaycar:
http://www.jaycar.com.au/productView.asp?I...eMax=&SUBCATID=
Can get them for $319 if anyone is interested also...
Edited by oRiCLe
waah quite expensive $300 ..huum probably will pass...custom boot instalation cost $800 that's like 1/3 cost....
I've got 600 w mono and 15" sub....is it possible to be run on the car battry charger?..huum computer power source...
might be enough to run the headunit but how bout the remaining system?
thanks for reply ...
I'm thiking to use cd player connect to amps, speakers and subs...because my headunit is now in my car....how to do the connection?
yah what happened if I put in too much power? kaboom? or is there some safety power cut thingy..
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
