1999 Skyline R34 GTT. Sliver in colour. 5 Speed manual.
19" Koya rims, 235/25 front, 275/30 rear (tyres done 2000km)
HKS Hyper-D adjustable coil-overs
Apexi Power FC
Apexi AVC-R
Kakimoto 3" stainless exhaust
65000km
Genuine Nismo factory fitted body kit
Alpine CD Player
Vehicle is in immaculate condition. I am selling to upgrade to a R34 GTR.
Asking $38000. ono. Phone Drew on (07) 3892 2555
https://www.sau.com.au/forums/topic/95690-skyline-r34-gtt/
  • 3 months later...
I think 33k is to cheap! A good tidy straight no pin dented GT-T manual that hasn't had crap stuck all over the dash is well worth 35k plus IMO, after a 3 month search for mine.
Hey R33_Cam, what mods do you have for 283+ HP?
https://www.sau.com.au/forums/topic/95690-skyline-r34-gtt/#findComment-2011586
