Hey guys.. just looking for a few opinions at the moment.. i'm considering going on a powerhunt soon for my R32.. and i'm undecided on which direction to go in.. i've been hearing all about rb24's, and rb30's running rb26, or rb25 top ends.. it's all a bit confusing.. anyone got any hard data on what can be achieved on these combo's, and what kind of mods woud be necessary to get the go?? i'm not looking for huge figures atm, but want a package that i can get serious with later .(serious=350+rwkw) Any idea's ???
https://www.sau.com.au/forums/topic/9571-power-hunting-on-my-r32/
RB20 has 78 mm bore and 69.7 mm stroke for 1999 cc's
RB25 has 86 mm bore and 71 mm stroke for 2476 cc's
RB26 has 86 mm bore and 73.7 mm stroke for 2570 cc's
So the RB20 has a 8 mm smaller bore which means smaller valves
which is why it doesn't flow as well as RB25's or RB26's. You can not put the bigger RB25/6 valves in an RB20 head. Also the RB25 or RB26 head can not be used on a RB20 block, the bore (78 mm) and combustion chamber (86mm) mismatch would make this unworkable.
Hope that helps
Hi HaZe, 350 rwkw is around 560 bhp. That's way beyond the economic power output for a RB20DET. Based on previous experiences;
We buy complete, rebuildable RB30ET's (Commodore VL Turbo) without accessories (turbo, a/c, p/s, alternator) for less than $A600. A complete RB25DE costs around $A1,300. We sell the bottom end of the RB25DE for $A400 and the head off the RB30ET for $200. So the net cost is $1,300.
The RB30ET is 3 litres (86 mm bore X 86 mm stroke) This is the same bore as the RB25's so the head fits straight on, using the RB25 head bolts. For racing, we change the rods to forged and the pistons (87.5mm for 3,104 cc's) also to forged ones. We use the standard crank which we balance and check for straightness.
The extra 628 cc's (25%) capacity over the RB25 (2,476 cc's) gives more torque, both on and off boost, plus it makes good boost earlier. The trade off is that it does not rev as well as an RB26DETT, but the total cost with a single turbo is way less than half for the same amount of power. Plus, because it does not have to rev as hard, it doesn't wear out as quick.
If you can do the engine work (not machining of course) yourself, the cost per Kw is unbeatable. If you have to pay someone to do it all for you, then it is not as attractive. Buy a low K's RB25DET and stick it in would be my suggestion. Leave the internals stock & then bolt on the go faster bits progressively. %THis would give you 450 bhp.
Hope that helps
So if you want to go for the 560 bhp, this is the sort of stuff we use....
* the turbo (say a Garrett GT30408BB) would be $3,000
* wastegate (a 45 mm Progate) would be $800
* set of equal length exhaust pipes, wastegate pipe & dump $1,600
* Camshafts (Jun 264's) $1,300
* Headwork $800
* Conrods $900
* Forged pistons $1,800
* Greddy drag intercooler $1,800
* balance and assemble $1,000
Total $13K.
Now at that sort of power the R32 GTST gearbox ain't gunna last, a R33 GTST one would be OK. They're about $800. Plus it will need a good clutch, a twin plate OS Giken is what we use, they cost $3K.
Hope that fills in some more gaps.
Hey Sydneykid... it sounds like you have a workshop?? is that so?? if so would it be possible to source the block and head thru you?? Also.. is it worth going a twin turbo setup? i have someone who can design, engineer and build any custom intake/exhaust manifold work.. i would just have to get some specs and pics of something similar, then get him to fine tune the design.. anyway.. thanks for all the lovely info.. not going to bothe rdoing any more mods to my little rb20 now.. might as well save for the real thing.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
