Just got my standard ecu remapped/dynotuned (rom tune from hyperdrive). Came up with 232hp at the wheels. DYNO GRAPH http://i13.photobucket.com/albums/a251/aut...ot/scan0003.jpg
My car is an 93 auto gtst with
gcg stage 2 R33 hiflow turbo (500hp)
full 3inch exhaust no cat and no spliter in the dump XFORCE system with 2 a midmuffler and rear cannon
apexi pod filter
gtr injector and z32 afm 040 fuel pump
front mount intercooler.
22$ boost controller still using the rb20 actuator with it presprung a little bit.
Does this sounds like a fairly decent power figure for an auto? i thought it was pritty low but yeah guy that did the tune seems to think its about all you will get from it.
ALso sometimes before it changes gears it goes on the limiter and take a while to change is this cause the auto can't keep up. Was thinking about getting a shift kit to fix this but dono if it would
Only problems i can think of that could cause lack of HP are:
I had to rotate the turbo housing cause BHDAVE had a himount manfold or something. Could the seal be leaking since i have done this and cause any problems. I doubt it cause air fuel ratios were good hyperdrive said and seems to hold boost fairly well. Also had a small crack in cooler piping but i patched it up with silcon hosing and put like 4 hose clamps on it (bit of over kill) but i don't htink its leaking
or
As someone mentioned the intake pipe is collapsing inwards with so much boost
Guy i brought the turbo off was running 12psi,with the stock injectors in it at this stage which is why the a/f ratio starts climbing at 6k and made 173rkw's http://image-cache.skylinesaustralia.com/f...-1132642989.jpg
Edited by AntonRx7
  • Replies 101
well i think thats what, 175rwkw?
thats pretty reasonable for the RB20... if my mind isnt leading me astray with the kw conversion
A good ECU is going to make a difference also thats for sure
it has gtr injectors
yeah it does feel faster actually runs nice. think maybe ill get shift kit as well to help out with shifting speed.
I just though only running 14psi for most the time is pritt shit.
It was done at hyperdrive in WA
it has a rom tune which is like putting a chip into it as its an auto so aftermarket is pritty hard to use
RB25 hiflow
i brought it of BHDAVE from this forum do you think maybe something could be wrong?
i am using a boost controller from the forums one of the 22$ ones, although the boost line seems to be normal i have been told so this must be ok. Just really thought i would have got more HP than i have
Edited by AntonRx7
yeah even though mines auto seems a bit odd doesn't it
could it be a boost leak from anywhere like the turbo or something i wouldn't have though so but i dono what else could be the reason. I am running more boost and on a hiflow turbo and you have more than me a bit odd. Wat dyno was yours on
you have an extra .5 of a litre but even then somethings is not right ay. Inlet temps were 50 i think it says on the dyno sheet to dono if that owuld make that much difference either
Looks like he's got not timing in there at all. Then again could just be a mushbox as well. Was the trans slipping?
can i point out that its a bit hard to call how laggy a turbo is without seeing the tune ?
Your assuming that all other factors are perfect.
if your timing is way out(cam belt slipped) for example it can be a pig to spool and make no power.
how would i know if my timing is not right. surley they would have told me if the timing was not right. I dono if the trans was slipping i would have thought they would have told me that too.
Did feel a bit quicker last nite as it was cooler but still dissapointed with the hiflow turbo
you got a continuous 170rwkw over 5500-7500rpm without it tapering off.. thats not bad to me from an auto RB20.. but you'd expect maybe another 10% I'd agree at least.
I have a feeling your wastegate is bleeding off boost after 17psi due to the spring not being strong enough.. afterall - its 10psi above (rb25 actuator?) the standard boost the wastegate is set for?
You'd really have to speak to somebody who has the same turbo on an RB20 and find out what boost they have to run to get xxx rwkw to get another base comparison.
Edited by predator2
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
