i think its just the rev limiter cause it just sorta doesn't really go or change gear for a little while after it happens and it doesn't always happen just sometimes. My speed sensor on my gearbox is a bit dodgey i think so may be a bit of a problem with that. Ill make sure its rev limiters tnite when i drive it again
  • Replies 101
Mine was just a single 1 piece dump/front pipe with a 3 inch catco cat and 80mm cat back with 2 mufflers.
The wastegate couldn't be leaking after getting a knock in the post could it?
good point, i should pay more attention.
When you run less boost does it come on boost earlier? I'm just thinking about the stock rubber intake pipe sucking closed. Also, what sort of filter are you running?
i dono have not tried it will give it a shot later,although i don't want to loose the boost setting atm as can be a bit of amission to get it set back right. i would not have though it would be sucking closed. its a Apexi pod filter also i have a right angle bend for the pod so it sits a bit further away from the engine as is closer to the outside air intake but i dont think this would matter either
thats the filter i have http://www.modyourcar.com.au/product_info....roducts_id=2604
I think it is that
4 of the best Tuners in perth told me it was
A) plug gaps
B) rev limeter
C) fuel cut
I used to have a blead valve and could not adjust boost properly but now i can adjust ot .3 of a psi
So C) was the correct 1 but only after they checked my gaps and tryed to run more boost looking for hp
i tune it my self with the help of turbo smart
if we have a cruz i will show you wat i mean
changed my whole out look on moding my auto
james
The pod shouldn't cause problems. They are one of the best flowing on the market. The pipes do suck in if they are a bit old and you are running a bit of boost, though it would have been spotted on the dyno i'd expect
Was not boost controler more the boost it self
i found the eboost2 very easy to work very precice
soo i could fine tune the controler and no dyno needed 4 that
just turn off the car start it and change boost settings from the cabin
and it a very acuate boost gauge as well some thing i through was a waste of time
how wrong i was
i have tuned mine so well i flat stick it and no more pops and more power cause engine is firing and ecu can handle it
best $915 i spent
james
yeah depends a bit on the dyno though as well some read pritty high. I have never heard of hyperdrive reading high seems they are quiet acurate. Do you have a manaul and rb25 though?
I am going to Mayhems thursday he is gona have a bit of a look he doesn't seem to think its right either
I have power and hold button on the auto umnm i think the computer learns
Edited by AntonRx7
yeah cause it takes a bit of time for it to change gears sometimes so would make it a bit slower. Boost seems to fluctuate up and down at the end of the rev range a bit as well as i have recorded it on my defi gauge dono if that is just from bouncing of the limiter. I will see if it does it tnite as i am not 100% sure if its is the limit. Either way still has got nothin to do with why its low on hp
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
