I dont know you might get 5 or 10 hp more maby and again it looks like a good safe tune
the next stage is ecu and igectors + pump so there is only so much hp out of some mods
go the shift kit and auto oil cooler and you might get a couple more hp
but with no 1/4 mile tests it is hard to say
Rev210 got into the 13s with not much more hp
james
  • Replies 101
Rev210's was an R33.. Different kettle of fish. :D
I believe Rev210 also had a few little aero mods, you know those little plastic bits that box off the stock intercooler? Rip those suckers out to stop it acting like a plastic bag in the wind.
Edited by Cubes
was that with a auto Miller?
my car has injector and fuel pump if thats wat your saying, and being auto makes after market ecu a bit hard, i would say the rom tune owuld be just as good anyway which is what i ahve got
What do you mean cubes? wat plastic i am a bit lost.
Edited by AntonRx7
No manual but is it hp and lack of it you are worried about not wat gear box it has
Emanage with inginion harnes for computer and the plastic behind your intercooler wheel arch thing rhs behind cooler pull that off
mine is auto so this thread intreast me
james
ohok umm maybe its different for r32 our cooler are on the passenger side and the old intercoolre is all gone.
Yeah i figure most people don't both with autos but i brought my car cause its in such good condition and though i'd give it a go at modding
I had to rotate the turbo housing cause BHDAVE had a himount manfold or something. Could the seal be leaking since i have done this and cause any problems. I doubt it cause air fuel ratios were good hyperdrive said and seems to hold boost fairly well. Also had a small crack in cooler piping but i patched it up with silcon hosing and put like 4 hose clamps on it (bit of over kill) but i don't htink its leaking
Edited by AntonRx7
took it for a drive just then it umm hard to expaain think its the limiter and it helps it change gear if you just take your foot of th accelerator a bit otherwise it take a bit longer to change gear
Also when i started car up it was a very very laggy/slugish for about 40second maybe it had a bit of water from when i cleaned the car though will see if it happens tomorow morning before walk
stupid cars
Edited by AntonRx7
i dono they defently didn't use much fuel as i filled it up before tune and the needle was still on full when i picked the car up. Maybe ill go speak to them thursday when i have a day off see wat they think about it. They don't seem to think it is capable of more HP due to turbo and gearbox thats wat they said when i picked it up
Short of the box being absolutely rooted, i can't see how that would be the problem, maybe the torque converter is slipping excessively? Is it worth seeing a gearbox specialist to rule out gearbox issues?
And the gcg highflows are capable of 250rwkw on rb25's so i don't see why 200+ isn't possible on an rb20 (and that's being conservative). The turbo made 199 on my rb25 at 14psi before i swapped it, that was only a couple of months before you got it. That was with 10:1 mixtures and no tune.
Who is good in perth with skyline gearboxs
i need a shift kit aswell but that needs to come from sa
there are a lot of autos being modded you think some one might pick it up and run with it
pfc as well
and your gear boxs is rooted i think i have a mate with a bombed supra 3lt and that happened had to get gear box rebuilt but it goes faster now
james
If it learns has it gone to far past the gear change learning thing
ecu reset will that help i wonder
it is faster when it does not pop isint it?
james
Try resetting the ecu. I found that this helped when I had shit shifts.
how much did it cost u to get a rom tune, i had hyperdrive tune my r33 rb 25 and got 215rwhp, didnt tell me they could do the rom
does anyone know how to extract power from a auto without to much drama's , seems as if everyone that buys one has trouble with this
you can't get a rom on rb25's i don't think.
How would i know if the gearbox is slipping would a shiftkit help solves this a bit?
so you don't think there could be a leak on the turbo or anything Dave?
i wouldn't say so but just want to rule that out as i did have to twist it and i have got silcon patching up one of the intercooler pipes.
There is a torque convert place near Hyperdrive i may go past there today as well see what they recon
I think it's a long shot that rotating the housings has caused a problem, i've done it numerous times myself on that turbo, aswell as my new turbo with no problems.
I'm only speculating that it is the box, it could be alot of things. You could have a cam out a tooth or slipped cam gear, could be a tired engine. The problem is that i'm in sydney and you're in perth and i'm trying to dagnose why the same turbo on the same type of engine is behaving in a completely different way to what it did on mine.
No troubles at all i have in an r33 rb2.5 250rwhp @ 10 psi
Auto
mods
full exhaust
pod
fmic
ebc
you just need shift kit ( insteed of clutch manual eqiv)
my next stage
emanage with ignision harnes
fuel pump and reg and ingectors
cam gear maybe
good wheels and tyers with alot of side wall flex
good 4 a low 13 id hope
james
Edited by Miller the hoon
Standard ECU is restricting u a bit, and u should probly get sum bigger injectors. 232rwhp is heaps low thats like 150rwkw like a standard engine makes. u sure its not 232kw at the rear?
Stock rb20dets dont make anywhere near 150 its more like 100-115
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
