is there any way of telling if its a cam gear slipped a tooth appart from taking off covers? I would have thought this wuld make the car drive like crap as well.
May take it down the quarter soon to see what it gets. Then decide if i should get shift kit
  • Replies 101
you can get the shift kit with filter kit from MV for like 400$ then ill just fit it not a bad price.
Went down to allfast torque converters and they said about 1350 for a 3000rpm histall as well. But yeah don't know if ill ever go that far
I only threw in the cam gear comment as a general example of a possible cause. It isn't very likely.
How much power did the car make with the old turbo? And when was the stock turbo hitting full boost and what boost were you running?
I just thought I'd come back to this one.. seeing as similar situation
Today I ended up getting only got 178rwhp in my R32 with RB25 highflowed turbo @ 16psi, turbotech boost valve, SAFC, fmic, nismo fpr, gtr fuel pump, and 3" full exhaust system.
The same turbo made 230rwkw (300rwhp) on an RB25 at 16psi... so it seems like a very similar situation to yours Anton. Decent turbo - but just doesn't seem to pull the figures on an auto RB20.. Maybe the turbo needs 20psi wring into it to really pull its efficiency range (wouldn't trust that on a stock rb20) ? and probably it requires proper management. But of course PowerFC won't of course run with auto...
Mind you it was about 30 degrees.. not shootout mode and that dyno reads quite low... but still, even if you add 10-20% for that, there is something about auto r32 that is funny here. You'd expect higher, and the engine has high compression and no other signs of ill-health. While the SAFC is not an ideal solution, you wouldn't think it would hold it back as much as it has.
Car feels pretty fast (and maybe is), so i'm not too disappointed... anyhow, thats enough rb20 for me. Will leave it as is for 3 months or so then rb25 + manual gearbox + powerfc is going in..
rb20 + auto :P bad combo..
It will make a difference however has the standard ECU been remapped? as this could help it out quite a bit, got a dyno graph with A/F ratios on it? is it losing out on the top end or all over the spectrum?
To add to this, we relooked at the tune on a cooler day and got about 250rwhp ( I think) out of it with a bit more adventurous timing and a little more boost. We tend to try and run a conservative package in timing if possible but Anton seemed a little disappointed with the previous result so we try to please.. :D
The auto basically gave up the ghost with the clutch packs/bands starting to smell after a few runs.
Anton seemed happy when he left and I hope the auto is still driving :)
Cheers
Ken
Anton, Drop a R32 5speed in it.. They are dirt cheap. :)
Look in to the patrol clutch, they are cheap and an upgrade over std, I'll assume they would be good enough for 200rwkw.
Manual... Better fuel economy, better life out of your brakes. Do it. :D
yeh, the gearbox are fairly cheap..but the rest are the fiddly bits and some are hard to get hold of these days.. minimum $1k + labour to get it done. anyhow, good luck with the quest anton for manual parts if you decide that route.
mine feels very strong.. at least 40-50% more power than stock and when it comes on boost you know about it.. so I'm not sure of the dyno reading.. a/f ratios are nice and even around 11.5 near the top end, and at least I know I can give it a hammering in the heat. Power just flattens off at the top and that is where it stays... will post a dyno sheet later.
Going to give it a drag strip run, that will give me a better benchmark..
I think really to get any more power out of mine (or any other highflow rb25 turbo for that matter), the answer would simply be more boost, and lots of it... at least 16psi+
I always forget about the labour side of things as I do everything myself. :D
But if the auto is shagged he is up for the cost of removal/install anyway so it may be a good time to consider the swap.
RB20's do indeed need lots of boost to get the air in past those small valves.
Edited by Cubes
You just need the stage 2 shift kit from MV in Adelaide to fix the hitting rev limiter problem.
I've had my auto for almost 2 years and I don't baby it. The only problem was hitting the rev limiter from first to second and slow gear changes. It was more obvious once I've put on a 3" exhaust. Once I put the shift kit in the problems were gone.
Also, the power you're makin does seam a bit low.
Mine has full exhaust, cooler, pod and stock rb25 turbo running 14 psi and makes 168 rwkw on a conservative dyno.
ECU chip is next.
Edited by nedb
just a comparison on the r33 auto cars, im interested in what other people are getting with there cars and what they have done to it. I have a 3" exhaust with split pulse dump pipe, 10.5 psi with GBF bleed valve, SAFC2 tuned by Hyperdrive, standard auto, standard cooler (soon to be fmic) and im getting 215rwhp and 1/4 mile of 14.7 at best.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
