Hi all.
i was wondering where people have mounted their temp-sensor for their oil temp guage?
after doing some searching i found that a few people have used an adaptor piece that screws into the stock oil-pressure guage oulet on the block.
Where could i purchase and adaptor piece like this???
cheers
Sam.
https://www.sau.com.au/forums/topic/95737-oil-temp-gauge/
A Google search on oil temp was enlightening and confusing to a degree. found a Volkswagen owners site, discussions on this topic. Evidently being air cooled those old things are extremely hard on oil and really need good monitoring of temps. Some of them go to the trouble of installing multiple senders, noting the different temps according to location.
The sump is probably the best "average" value, being the reservoir from which the whole lubrication system is fed. The oil pressure sender is not subjected to full flow (that I am aware of) and a take-off there may not accurately show the temps of the main body of oil.
cheers
Dale
https://www.sau.com.au/forums/topic/95737-oil-temp-gauge/#findComment-1733646
thanks for that info. yep, ive now read that the sender must be fully submerged in oil to get an acurate reading. Also interesting to find some cars use oil temp senders for both before/after oil passes through the oil-cooler, to get 2 different readings!
Still unsure of where to mount it though, the GReddy sump plug replacement type seem the easiest, but that point is very low to the ground and i would hate to scrape it on anything...
the sandwhich plate option is about $50-60, so at that price its almost worth spending a bit more to get an oil cooler kit that has the adaptors anyway...
hmm, not sure..
Sam
https://www.sau.com.au/forums/topic/95737-oil-temp-gauge/#findComment-1734278
i've got one installed in a sandwich plate behind the oil filter in the stock position. i'd prolly go a filter relocation kit with the appropriate sensor fittings for next time - might get a semi-oil cooler effect from that too without splurging on a full oil cooler.
i've found that oil temps obtained from sump locations tend to be a little lower than the temps obtained from a sandwich plate under the filter (5-10 degrees)...
https://www.sau.com.au/forums/topic/95737-oil-temp-gauge/#findComment-1736048
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
