ok in the last two weeks my car has started doing this. when i'm driving the car to work in the morning, probably every second day the car completely shuts itself down.
it usually happens when the oil is at 10 degrees below normal temperature.And everytime, the hicas light comes on and then the 4wd light follows. then the engine loses power and stops.
then after this happens it takes almost an hour for the car to start again.Also when i try to start the car the fuel pump doesn't make the buzzing sound like normal.
the car is stock except for a cat-back exhaust, oh and it is an r32 gtr
any help is really appreciated
https://www.sau.com.au/forums/topic/95739-engine-shuts-down/
I had this problem 2 weeks ago, and it is already fixed, it cost me $470. Mechanican changed 4 sparkplugs and replace some thing to control the fuel go into the engine because the fuel wasn't burning completely. So first, u can try to change sparkplugs and see how it goes. That may save u some money.
How old is your battery? Skylines are notorious for their susceptibility to voltages and charge rates.
The other possibility is the ignitor module for the coils - they tend to be susceptible to excessive heat and will often stop until given the chance to cool off a bit.
yeh that sounds like it could be it, it happens intermittently just before the oil gets to working temp, but it doesn't happen all the time, 70% of the time it drives fine
although usually before it happens the car has a slight miss, sorry to hear about you're car what replaced it?
My car is doing this also. It was fine before I took it to the mechanic, he replaced the AFM cause they said the car was running lean. Now it drops out on me and has flat spots. I usually just wait a minute before starting it again and then it seems to be ok. It happended for a couple days. Then i fiddled around with the AFM it didn't do it for 2 days.. now its doing it again. So i'm guessing the mechanic put in a dodgy AFM. Or maybe its the fuel pump. I have to take it back and get them to look at it. I just hope this doesn't cause any damage to any other parts of the engine, the turbo especially. All of the misfiring and stopping and starting.
do you know what the part was that the mech changed?
So have you fixed ur car?? because my car just happen exactly the same problem again. And i don't want to spen any more money on this, what did you do for ur car. and do you know where are the spark plugs, i can't find where it is.
Well thats a good one. Spark plugs are under your coil pack cover. The aluminium bit that goes over your engine head (In the middle). Under that you have your coil pack, then under that are your spark plugs. =)
Do you have an Rb20,25 or 26? The Rb20, you might need to take off the oil hose on the top first.
Well done, I hope your C.A.S. was the problem... how much did you spend all up to fix your problem?
Thanks. B)
Thanks.  B)
First, I spent 470, then 3 weeks later it seem like happen again, machanican recomenced me to change bigger muffler becaue it can burn more fuel. I bourgh a full Apexi muffler system, it cost me only 520, now car works perfectly.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
