TIME HAS COME TO SELL MY GTR BECAUSE I WANT TO GIVE DRIFTING A GO AND THIS CAR HAS TO MUCH POWER AND IS SET UP FOR STREET OR DRAG AND WOULD COST TO MUCH TO CONVERT IT INTO A DRIFT CAR
ENGINE MOD:
8000 KM ON ALL AFTERMARKET PARTS
VENOLIA FORGED PISTONS
N1 OIL PUMP
N1 WATER PUMP
PORTED HEAD
MATCHED PORTED INLET AND EXHAUST MANIFOLDS
HEAT TREATED HEAD
NEW EXHAUST VALVES
NEW INLET VALVES
TOMIE STEP 2 CAMS
OS GIKEN TWIN PLATE
SHOT PEENED RODS
HKS HEAD GASKET
HKS EXHAUST MANIFOLD
HKS GT WASTE GATE
HKS TO4R TURBO
HKS ADJUSTABLE CAM GEARS
HKS 106 MM INTERCOOLER
HKS PLUMBIMG
SARD INJECTORS
NISMO ADJUSTABLE FUEL REG
BOSH IN TANK FUEL PUMP
APEXI POWER FC COMPUTER
APEXI BOOST CONTROLLER
APEXI HAND CONTROLLER
VEILSIDE 80 MM EXHAUST
REBUILT FRONT DIFF
TWIN PUFF BOV"S
FULLY POLISHED ENGINE COVERS
CAR MADE 518 HP AT THE WHEELS ON 18 PSI
CAR MODS:
NISMO BODY KIT
BILSTEEN SUSPENSION
18 X 9.5 INCH DRIFT R WHEELS
CARBON FIBRE BONNET
GREEDY PILLER MOUNT
GREEDY GAUGES
ALPINE CD PLAYER
TINTED WINDOWS
DELETED WING
NEW PAINT JOB
86000KM
PLEASE NO TEST PILOTS, SERIOUS BUYERS ONLY
WILL TRAVEL TO SHOW SERIOUS BUYERS
$42000 o.n.o (will consider trade for drift car with cash adjustment)
0400666483
https://www.sau.com.au/forums/topic/95760-big-hp-r32-gtr/
  • 1 month later...
no thats not correct. i sold the car about a year ago and i am posting it back on here for the owner because he is a mate of mine.
since i have sold the car its had a full respray and carbon fibre bonnet and has also had it tuned.
still for sale at $37000 (trades welcome)
https://www.sau.com.au/forums/topic/95760-big-hp-r32-gtr/#findComment-1878258
Guest
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
