I have the RB25NEO in place. The rear is back together and now I'm looking at replacing all the bushes in the front end.
I did noticed there was some discussion about alternative steering solutions, did somebody actually figure anything out?
If not. What is the car like to drive without powersteering?
https://www.sau.com.au/forums/topic/95762-steering-solutions/
Why have you removed your power steering?
The front suspension of mine is basically all new, bushes/springs and shocks, and it's generally the same as before just stiffer due to the sports suspension.
If you want to improve your steering response, try getting an R32 seering rack into there
Well,
I got a power steering reservior off an R31 and I made some new pipes at work. Then had some new fittings made up so as soon as im finished painting I'll be able to drive away with power steering.
Other quick question, did the bushes in the front come as a set or did you have to order them all separatley?.
and from memory i think the engine came out of a Four door R34 25GT-X.
