Hi all
Looking at a 3" turbo back for a R34.
Would like some help or advice about a good system.
Requirements:
- good power gain
- quiet
- preferably non canon muffler (twin tip muffler / oval muffler with tip would be nice)
I was looking at getting BATMBL's split dump and maybe one of his cats or a magic cat (Whats better?). A jap branded cat back would probably be on the list too. Unfortunately most of them are canon style mufflers.
However I would like the exhaust to be as quiet as possible as I am not a big fan of loud exhausts.
Any ideas or suggestions?
https://www.sau.com.au/forums/topic/95768-best-exhaust-system-for-a-r34/
Hi all
Requirements:
- good power gain
- quiet
I don't think you can go past CES's system. I didn't get one from them and I know my car is very loud (but very unrestricted). Mine is just a 3" split dump pipe system with hiflow cat, hotdog resonator and cannon (with removable silencer makes it much quieter).
The CES system that a few people have bought comes with a 3" split dump pipe system with cat, resonator and a twin tip magnaflow muffler and it is much quieter and doesnt have the annoying drone. And because of the research etc that CES has done, they are pretty good flowing too (not too restrictive and dyno proven).
If you want quiet, the Fujitsubo ones are known to low noise and also don't have a cannon tip.
The Stagea guys seem to like it:
http://www.skylinesaustralia.com/forums/in...showtopic=90146
What cat do you guys recommend?
- 3" Magic Cat with 4" body (rated pretty highly by people here and come with bolt on optionm no idea what the flow rating is) ~ $300
- 3" big body BATMBLS Catco cats? (seem to be the highest flowing 706cfm with bolt on option) ~ $440
- Metal Cat
And when they say bolt on, does that mean the cat will bolt on fine inbetween teh dump pipe and the cat back exhaust?
I found this quote on a website:
"(Catco) 706CFM FLOW RATE with the 3" piping! NOTHING else comes close, since the 3" Metal CAT flows 629CFM and the 3" Magic CAT (with the 4" body and 3" cone reducers welded to it) flows 540CFM. All 3 CATs were independantly tested at the same site on the same machine."
Hmm kinda confused now as different people say different things.
Edited by nuffsaid
What do you guys rekon of a Fujitsubo twin system like the one below:
Pipes are smaller, and more bends, but 2 pipes. How would it compare to other single pipe quiet cat back systems?
And is the layout for the R33 cat back systems the same as the R34? I was wondering whether I could buy a cat back for a R33 so it would fit the 34?
Edited by nuffsaid
Yeha kinda interested in the CES magnaflow system too, purely because I can get a twin tip muffler (quite like the look)
Unfortunately, its pretty much the same price. I suppose with the CES system I wont get as much R&D as the Fujitsubo system. I hear fujitsubo make one of the best exhausts out there and well its proven I';d say.
CES have yet to make a system for a 34 I think.
CES have fitted a few R34's with systems (owners here on the forums). All I can say in terms of the difference between a very high flowing loud system and a CES System is volume by a lot on the outside and pretty much no drone on the inside. The performance when considering relatively stock cars is negligble.
I mean if R34GTX's 7 month year old baby can sleep the whole way through a cruise up and down hills, I'd say its quiet.
On that note though, if you are planning serious mods, you may want to consider a more expensive or freer flowing system like the more expensive jap brands OR, get a cheap high flowing system with whatever tips you want and get an Apexi Exhaust Controller Valve (electronic costs a bit more than the lever operated one). That way you can have an easily switchable system. Not 100% on the legality though.
Some R34 GTT or R34 GTX-T's came with an exhaust volume control (only 2 or 3 settings though) from the factory.
I guess the question is for $1200 would you buy a CES system or a Fujitsubo?
See:
http://translate.google.com/translate?u=ht...Flanguage_tools
The only thing I know of at the momment is that I like the CES twin tip, other than that, I think the Fujit wins in terms of performance, build quality etc.
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
