Hi guy si just signed up on this site maybe 20 min ago. Hopefully itll be kindof useful, i can imagine it will be.
I drive a C34 Stagea (97 rs four), that i bought 3 weeks ago. as im sure you have all been told, though a diagonal line across the grille and yep mates thats a volvo. Well its not, but try telling THEM that.
Im after a Body kit guys. Like an autech version kit or something similar. been searching for any form of body kit for a stagea for weeeeks and cant find a thing. am i missing something?
cheers
rob
https://www.sau.com.au/forums/topic/95771-stagea-body-kits/
  • Replies 105
27th... tomorrow!?!? um i have no idea - get back to me quick - when and where, em?
and youre in burpengary eh, ska? love to meet up. master_robbo@hotmail is my email and msn. get in touch man.
https://www.sau.com.au/forums/topic/95771-stagea-body-kits/#findComment-1744852
thats a sweet looking kit. looks pricey but... i really have 1500 to spend to cover it all, not including painting. ive got that covered. waiting to hear back from dmd...
yellow hey... about as tough as a bowl of custard
Edited by qikstagea
https://www.sau.com.au/forums/topic/95771-stagea-body-kits/#findComment-1745002
I'm not a fan of the yellow either, and all the sII manual Stagea's that I found were ALL that colour, which annoyed me no end.
Luckily I had my eye on a manual-converted sI, and it was still for sale when I'd managed to gather enough money to contact the owner... And it's dark green, which is one of my favourite car colours.
https://www.sau.com.au/forums/topic/95771-stagea-body-kits/#findComment-1745200
That yellow one has the same kit as DMD, the front grill I can't remember if they have or not and from memory the front bar looked a bit different, but the rest is all the same, as I've seen a silver one they put a kit on. Looked good!
Really ... how much are the FB's again?? As thats a hot bar, and would mean both my cars have the same front bar! :angry: (adds to long term shopping list).
do DMD do that bonnet on that car ... l'm seeing that in black on my car!! :angry:;)
https://www.sau.com.au/forums/topic/95771-stagea-body-kits/#findComment-1746403
yeah thats the sort of bonnet im after too. subtle but gets the job done. would probably go black as well, or hell i dunno. havent heard back from dmd still, will have to up the ante and call them. get some pricings. anyone know any toher suppliers to add to the list?
https://www.sau.com.au/forums/topic/95771-stagea-body-kits/#findComment-1746424
my bad - just heard from them.
"Yes we do Rob. The kit consists of front and rear bars, side skirts, and a hatch wing. The cost will be 1800 for the full kit. The fitment is perfect and straight bolt on.
thanks
Doan"
righto then. pricey.
https://www.sau.com.au/forums/topic/95771-stagea-body-kits/#findComment-1746429
Yep, but thats what we get for owning Stagea's :) Much better than getting one from Japan....from Yahoo - When I have the money I will be buying this kit, personally I dont think its such a bad price. Looks stunning though, I love i t:D Cheers for finding that out
https://www.sau.com.au/forums/topic/95771-stagea-body-kits/#findComment-1746583
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
