Hey guys, I purchased my N/A R33gts25 over the weekend and i'm firstly looking to change the stock exhaust/muffler... I've done a bit of searching around the forums and reading... But still a little unclear on some things...
I'm not interested in power modifications ( but don't want to lose power ) as I'm on my P's and it isn't worth the hassle with the new restrictions... i'm just after a nice drive with a nice sound output. That being, nothing too loud that gives you a head ache... just something quiet that kicks in a bit when you give it a nudge...
Specifically on sound, something that has the stock sound of the twins im using at the moment ( that ferrari'ish sound lol ) with a little bit more depth would be awesome... Pretty sure most of you know the sound i'm talking about.. i'll try get a sound file of my current exhaust..
So, should i be searching around for something like this http://www.autobarn.com.au/default.asp ( a complete system )
Or should i just look around for mufflers?
Any help is greatly appreciated :P
Edited by ignuz
https://www.sau.com.au/forums/topic/95776-na-mods/
if you want a really nice sounding exhaust that is not loud, get a "remus" or a "hi-tech" system. be prepared to pay for it though
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1733525
mm also.. i just got off school and was walking down my back lane.. and my neighbour had a box saying kings springs on it.. performance etc etc i was like errr ok.. kicked the box.. and it was full.. thought to my self.. no way.. opened it up and there's four in there... could they be damaged? Or should i go get em?
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1734633
They probably wont fit a skyline mate, unless they are specifically for your model dont bother. go order some king springs, or k macs like i did, and then i got pedders shocks to go with it. Do it right, do it once.
Dayne
just took a pic anyway ( what size are your springs? )
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1734772
Bit hard to tell if they would fit by pictures, you actually need the code number and ring up king springs and ask what car theyre designed to fit... most likly if they arn't skyline they wont fit as they wont sit in the bottom and top of the strut properly.
Mine are 3.75" lowered kmac's.... they are a much wire and thicker spring by the looks of it. Though bit hard to tell by the picture
Dayne
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1735007
I'm also looking around for some new wheels n rims.. should i be looking for a certain size? offset etc?
Also...I've been looking around some of the links on here at places that sell some wheels etc like garage 13.. do yuo guys know of any other places that stock a lot of new and used wheels n rims?
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1736574
thanks :) fellow rb25de'r
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1736623
not that I know of. cheapest way to get one is to convince someone who has an N/A who's turboing their car and has aftermarket extractors to sell em to you :)
(and no, I'm not turboing my car)
here's the webpage for it:
http://www.fujitsubo.co.jp/mc-prod/psrs-v.php3?id=00000086
here's one at yahoo for an R33 GTS25
http://page13.auctions.yahoo.co.jp/jp/auction/r19118868
only $1300 :D The reason they're exxy is because their custom made items, ie you place the order and they make one for you.
I've got some pics of it on my car, I'll see if I can dig em up.
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1736701
If its too big, yes, you will lose power as you still need some decent backpressure on N/A's. However there's also no point fitting a high flow cat back exhaust when your extractors don't flow for shit. Your system's only as good as its smallest bottleneck.
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1747480
extractors are worth doing. if you do them with a cat back exhuast then you get the best gains. pipe sizing for N/As are pretty much rb20e/de 2.25" and rb25de is 2.5" that is mandrel bent.
when i put my rb30de in i will keep my current 2.5" mandrel bent exhuast that i currently have on my rb20e. its far to big to be good for any low down power
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1747974
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
