Hey guys, I purchased my N/A R33gts25 over the weekend and i'm firstly looking to change the stock exhaust/muffler... I've done a bit of searching around the forums and reading... But still a little unclear on some things...
I'm not interested in power modifications ( but don't want to lose power ) as I'm on my P's and it isn't worth the hassle with the new restrictions... i'm just after a nice drive with a nice sound output. That being, nothing too loud that gives you a head ache... just something quiet that kicks in a bit when you give it a nudge...
Specifically on sound, something that has the stock sound of the twins im using at the moment ( that ferrari'ish sound lol ) with a little bit more depth would be awesome... Pretty sure most of you know the sound i'm talking about.. i'll try get a sound file of my current exhaust..
So, should i be searching around for something like this http://www.autobarn.com.au/default.asp ( a complete system )
Or should i just look around for mufflers?
Any help is greatly appreciated :P
Edited by ignuz
https://www.sau.com.au/forums/topic/95776-na-mods/
if you want a really nice sounding exhaust that is not loud, get a "remus" or a "hi-tech" system. be prepared to pay for it though
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1733525
mm also.. i just got off school and was walking down my back lane.. and my neighbour had a box saying kings springs on it.. performance etc etc i was like errr ok.. kicked the box.. and it was full.. thought to my self.. no way.. opened it up and there's four in there... could they be damaged? Or should i go get em?
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1734633
They probably wont fit a skyline mate, unless they are specifically for your model dont bother. go order some king springs, or k macs like i did, and then i got pedders shocks to go with it. Do it right, do it once.
Dayne
just took a pic anyway ( what size are your springs? )
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1734772
Bit hard to tell if they would fit by pictures, you actually need the code number and ring up king springs and ask what car theyre designed to fit... most likly if they arn't skyline they wont fit as they wont sit in the bottom and top of the strut properly.
Mine are 3.75" lowered kmac's.... they are a much wire and thicker spring by the looks of it. Though bit hard to tell by the picture
Dayne
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1735007
I'm also looking around for some new wheels n rims.. should i be looking for a certain size? offset etc?
Also...I've been looking around some of the links on here at places that sell some wheels etc like garage 13.. do yuo guys know of any other places that stock a lot of new and used wheels n rims?
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1736574
thanks :) fellow rb25de'r
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1736623
not that I know of. cheapest way to get one is to convince someone who has an N/A who's turboing their car and has aftermarket extractors to sell em to you :)
(and no, I'm not turboing my car)
here's the webpage for it:
http://www.fujitsubo.co.jp/mc-prod/psrs-v.php3?id=00000086
here's one at yahoo for an R33 GTS25
http://page13.auctions.yahoo.co.jp/jp/auction/r19118868
only $1300 :D The reason they're exxy is because their custom made items, ie you place the order and they make one for you.
I've got some pics of it on my car, I'll see if I can dig em up.
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1736701
If its too big, yes, you will lose power as you still need some decent backpressure on N/A's. However there's also no point fitting a high flow cat back exhaust when your extractors don't flow for shit. Your system's only as good as its smallest bottleneck.
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1747480
extractors are worth doing. if you do them with a cat back exhuast then you get the best gains. pipe sizing for N/As are pretty much rb20e/de 2.25" and rb25de is 2.5" that is mandrel bent.
when i put my rb30de in i will keep my current 2.5" mandrel bent exhuast that i currently have on my rb20e. its far to big to be good for any low down power
https://www.sau.com.au/forums/topic/95776-na-mods/#findComment-1747974
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
