What would you do?
7 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Well, i've lunched the turbo on my RB20 on the way to work today...
It was the compressor blades that broke (not exhaust like normal) and there is fine metallic dust through the intake, and it appears to be on the tops of the pistons as well... Now, i found larger chunks of metal through the intake, i just don't know if any of those made it into the engine....
Now, the choices i have are:
Put another turbo on and hope for the best
Buy a wreckers engine and hope for the best
Get my current engine rebuilt
Now, there are pros and cons of each.....
Pros for putting another turbo on....
Cheapest option
Cons for putting another turbo on....
Could spend money/time putting it on only to find the engine is fubar, and be in exactly the same situation
Pros for buying a wreckers engine....
'relatively' cheap option
Cons for buying a wreckers engine....
don't know past history, it could have been thrashed, on the verge of death etc... could only last a month or 2 before it dies and then i'm back in exactly the same situation
Pros for rebuilding the engine....
Will be a brand new engine, you know exactly whats done to it, how its been treated, should last for years and years to come (i'm looking to keep the car for a fair while hopefully, as it owes me too much money to sell), the engine has 190000km on it anyway, so its just about due for a rebuild...
Cons for rebuilding the engine....
Is the most expensive option
What would you do in this situation?
Keep in mind that i need the car for work, but i could probably get away without it for a week or 2....
https://www.sau.com.au/forums/topic/95779-where-do-i-go-from-here/
I very much doubt that your engine has sustained damage. Reason I say that is that any metal pieces would have to make their way through the intercooler before ending up in the engine. This alone would probably ensure that only the finest particles would end up in the engine. It is possible that the engine is damaged, but as you are going to have to replace the turbo anyway then I would do that first and then see what happens from there.
i would take all the piping out and the intercooler and even the inlet manifold and clean it all as much as you can that way if there is nothing in the intake to destroy your engine if its not allready destroyed if you put a new turbo on then your home free.
Last thing you want is having to put the turbo back on and it run great for 2 weeks then the engine spits it.... take the time and work out where your at first before inspecting the bank account for a rebuild.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
