Im gettin a new exhaust fitted on friday and i was going to buy a HYBRID setup to bolt straight on(so to speak). But...the exhaust guy said that he can get one almost identical to hybrid for a few hundred less. i think its Japanese from what he said. Has anyone used an imitation something like this? should i stick with the hybrid? :P
https://www.sau.com.au/forums/topic/95786-hybrid-imitation/
i guess your talking about hybird copy aka chinacopy coolers;
you can pick one up now adays for between $200 - $400 depends where you buy, they are good but you get what you pay for so basicly a REAL JAP SPEC cooler (ARC,Apexi etc etc) will always be better than a cheap china copy.
But saying that im running one without problems and i know people pushinh 400-450rwhp without a problem too :P
https://www.sau.com.au/forums/topic/95786-hybrid-imitation/#findComment-1733598
there is nothing wrong with the china copy coolers. they look quite good and do the job perfectly, however they are very heavy...
I have had one and would have one again. However if i could find a gtr cooler for the same price i would pick the gtr cooler.
https://www.sau.com.au/forums/topic/95786-hybrid-imitation/#findComment-1733681
This is a stupid arguement, and I really think some people miss the point entirely.
Hybrid has achieved what they set out to achieve by creating a 'brand' name for themselves which leads consumers to compare the quality of some coolers and other products on the market to the 'genuine Hybrid' item.
On the subject of intercoolers,Hybrid were basically the first company to tap into the cheap intercooler market with the intercoolers made in China and Taiwan but after years of having the cheapest coolers around, every man and his dog now knows which factory they come out of and is buying them direct.
Intercoolers, exhaust systems and other products from China and Taiwan surprisingly are of a very high standard and really are a decent quality product. The cheap intercoolers that flood the market handle some decent power figures too - up and in some cases over 300kw in fact.
The majority of the exhaust systems and manifolds that are now available are also of a high standard
Cliff notes: Comparing a 'hybrid' product with a typical china made intercooler is pointless, its the same product, only hybrid bungs a plate on the top to brand these coolers and other products as their own.
Considering places like Just Jap sell these intercoolers for $175 delivered on this very forum, I dont think you can go wrong - I will be fitting one on my GTS-T shortly and I have looked at enough of them to be satisfied with the quality.
https://www.sau.com.au/forums/topic/95786-hybrid-imitation/#findComment-1733753
am i missing something here...? isn't he asking about exhaust not I/C?
the exhaust guy is probably looking at getting you an X-force exhaust.
they are quite a bit cheaper than most other stuff around, but are still of a reasonable quality. pretty loud exhaust, bit droney tho
either way, found out exactly what you are getting and research what you should be paying for it. nothing worse than finding out a week later that you paid too much :P
https://www.sau.com.au/forums/topic/95786-hybrid-imitation/#findComment-1733766
What Blitz said !! And if you doubt the quality of thsee intercoolers that are coming out of China, give Steve a call at Just Jap and he'll tell you about the facility they are built in and the quality control testing they put each and every intercooler through before releasing them for use. :P
With that said though, in general, I still don't condone the way that one company spends big $'s on R & D only to have their product copied ( sometimes very poorly ) by some sweat shop in China !!
https://www.sau.com.au/forums/topic/95786-hybrid-imitation/#findComment-1733805
sorry i may have worded it wrong at the start. i am gettin an exhaust fitted friday AND also getting a FMIC. and the rest explains itself. but my exhaust guy is saying he'll charge about $800-$850 fully fitted for the lot. is this roughly a common price for those guys that said they have these systems fitted?
https://www.sau.com.au/forums/topic/95786-hybrid-imitation/#findComment-1733919
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
