Im gettin a new exhaust fitted on friday and i was going to buy a HYBRID setup to bolt straight on(so to speak). But...the exhaust guy said that he can get one almost identical to hybrid for a few hundred less. i think its Japanese from what he said. Has anyone used an imitation something like this? should i stick with the hybrid? :P
https://www.sau.com.au/forums/topic/95786-hybrid-imitation/
i guess your talking about hybird copy aka chinacopy coolers;
you can pick one up now adays for between $200 - $400 depends where you buy, they are good but you get what you pay for so basicly a REAL JAP SPEC cooler (ARC,Apexi etc etc) will always be better than a cheap china copy.
But saying that im running one without problems and i know people pushinh 400-450rwhp without a problem too :P
https://www.sau.com.au/forums/topic/95786-hybrid-imitation/#findComment-1733598
there is nothing wrong with the china copy coolers. they look quite good and do the job perfectly, however they are very heavy...
I have had one and would have one again. However if i could find a gtr cooler for the same price i would pick the gtr cooler.
https://www.sau.com.au/forums/topic/95786-hybrid-imitation/#findComment-1733681
This is a stupid arguement, and I really think some people miss the point entirely.
Hybrid has achieved what they set out to achieve by creating a 'brand' name for themselves which leads consumers to compare the quality of some coolers and other products on the market to the 'genuine Hybrid' item.
On the subject of intercoolers,Hybrid were basically the first company to tap into the cheap intercooler market with the intercoolers made in China and Taiwan but after years of having the cheapest coolers around, every man and his dog now knows which factory they come out of and is buying them direct.
Intercoolers, exhaust systems and other products from China and Taiwan surprisingly are of a very high standard and really are a decent quality product. The cheap intercoolers that flood the market handle some decent power figures too - up and in some cases over 300kw in fact.
The majority of the exhaust systems and manifolds that are now available are also of a high standard
Cliff notes: Comparing a 'hybrid' product with a typical china made intercooler is pointless, its the same product, only hybrid bungs a plate on the top to brand these coolers and other products as their own.
Considering places like Just Jap sell these intercoolers for $175 delivered on this very forum, I dont think you can go wrong - I will be fitting one on my GTS-T shortly and I have looked at enough of them to be satisfied with the quality.
https://www.sau.com.au/forums/topic/95786-hybrid-imitation/#findComment-1733753
am i missing something here...? isn't he asking about exhaust not I/C?
the exhaust guy is probably looking at getting you an X-force exhaust.
they are quite a bit cheaper than most other stuff around, but are still of a reasonable quality. pretty loud exhaust, bit droney tho
either way, found out exactly what you are getting and research what you should be paying for it. nothing worse than finding out a week later that you paid too much :P
https://www.sau.com.au/forums/topic/95786-hybrid-imitation/#findComment-1733766
What Blitz said !! And if you doubt the quality of thsee intercoolers that are coming out of China, give Steve a call at Just Jap and he'll tell you about the facility they are built in and the quality control testing they put each and every intercooler through before releasing them for use. :P
With that said though, in general, I still don't condone the way that one company spends big $'s on R & D only to have their product copied ( sometimes very poorly ) by some sweat shop in China !!
https://www.sau.com.au/forums/topic/95786-hybrid-imitation/#findComment-1733805
sorry i may have worded it wrong at the start. i am gettin an exhaust fitted friday AND also getting a FMIC. and the rest explains itself. but my exhaust guy is saying he'll charge about $800-$850 fully fitted for the lot. is this roughly a common price for those guys that said they have these systems fitted?
https://www.sau.com.au/forums/topic/95786-hybrid-imitation/#findComment-1733919
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
