Shipping Methods For Larger Items Japan -> Aus
Yeah ok... deal is air IS 3 metres with a max length of 1.5metres and they stuffed up. The reason for the mistake is that sea is 2 metres with a max length of 1.05 metres... they got confused and said that was the max limit for both :angry:
currently struggling to get an exhaust system for an R34 under max size... I HATE large packages :pinch:
  • Replies 45
Streeter, thanks for that... still 20kg sea and air though right?
Also, do you have an approx weight for that exhaust? Ive got someone wanting a system for a s13, Im trying to explain to them it may be very expensive if I have to split the system in 2 parcels if weight goes 20+
Might as well ask here too... anyone heading to the Automesse on the sunday?
cheeRS
glenn
yeah 20kg max for both...
the r34 cat back is going to have to go in 2 pieces and weight is roughly 7-8kg for each piece. has to go via air though as the pieces are longer than 105cm :pinch:
Ill go to Automesse if I score free tickets otherwise cant really be bothered but I think L is going.
Edited by Streeter
Yeah ok...  deal is air IS 3 metres with a max length of 1.5metres and they stuffed up.  The reason for the mistake is that sea is 2 metres with a max length of 1.05 metres...  they got confused and said that was the max limit for both  :D
does that mean we can get seats ?
drift007 reckons a reclined recaro is under the 3 metre limit so therefore can be sent but only via air as the dimensions are too big for sea. Bit of a shame as sea is roughly half the price. Also he mentioned that it only makes it under if the packing is done with bubble wrap which I think is a little risky given my experience with post LOL
Trouble will be if another type of seat is just over the maximum and then Im stuck with it here.
worst case scenario you can chuck it in one of our containers, but its not really a regular thing, so it might not see australia for 2 or 3 months.
i sent like about 30 or so bride brix seats through EMS back when i bothered doing it. out of the 30 about 5 were taken for customs. and only a single on was ever damaged. it had a small knife cut that apparently looked like the work of a box cutter which drew me to the conclusion that maybe customs did it to get a look inside the seat with a camera. you should be safe sending it i think. just write a high value on the insurance side of the form and that way if its damaged you can rape them. insurance is only like 100 yen anyway.. YOU CAN DO IT..... backend of 4 chu his here hahaha
if you have a high insurance value then you'll have to pay unnecessary taxes when it gets here. Its sorta like betting on them damaging it.
Well if drift007 is certain and I have funkey as a back up if it doesnt come in under max size then Im willing to get seats if anyone is keen.
just let me know :D
I agree with funkey, the whole reason you would bother importing is to get it cheaper in which case Id recommend going the other way and undervaluing it to lower/dodge tax and hoping that it isnt damaged in transit.
  • 3 months later...
thought I'd add a point here....
I got stuck with a spoiler - purchased it for a customer, I'd guestimated that it would fit under the limits... wrong...
anyway - rang up takkyubin - and they said no problems. EMS, and exactly the same price as the post office.
beats using UPS and paying x3
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
