Hi guys,
I've had my r33 for about a year now, just wondering about
getting a -little- more power out of it. everything is stock on it except for a k&n inbox air filter (wet), and boosted to 10psi.
Currently is 149.7rwkw. Is there anything more I can do, without changing intercooler, turbo, exhaust, filter, ecu, re-map fuel, etc.
just to sqeeze a little bit more out of it --- rwkw 170's maybe...
Thanks,
https://www.sau.com.au/forums/topic/9582-need-more-power/
Well, you could try a full port and polish, cams and cam gears... but why dont you want to do the normal things most people do when after a little bit more - there is a reason that people follow that path.
I would personally think of 20rwkw as a reasonably significant gain in power.
https://www.sau.com.au/forums/topic/9582-need-more-power/#findComment-146164
I don't mind spending a few hundred, but not a few 000.
i would'nt mind getting at cat back exh, but the gf will complain - I used to have an r31 b4 this one, with had a cat back sports - she drove me nuts with complaints 'bout headaches...
I don't wanna touch the motor, and don't wanna spend 000's on new turbo's, intercoolers, powerfc's...just wanna little more kick...
was reading some forums the other day, and a member (can't remember who?) - his avator was something like stock everything, 10psi and something crazy like ~180rwkw???
just wanted to know what he did...I'm a bit of a newbie when it comes to this sort of stuff - may seem like a silly question - but what a pineapples??? - have heard them in forums. he also mentioned something about factory ecu & connecting something to it (safc???)
thanks.
https://www.sau.com.au/forums/topic/9582-need-more-power/#findComment-146381
1995 R33 GTS-T
67,000km
3" Cat back Nismo Exhaust
HKS Pod Filter
FMIC
EBC
(Possibly chipped ECU but no proof)
7psi - 168rwkw
12psi - 192rwkw
If you want abit more oomph get a full 3" Exhaust System. Should cost you around $800ish and if you get a decent type/brand they really aren't loud. A mate had an R31 and it was SOOO loud i'd get a headache after 2km but the propper exhausts are seriously quiet.
Their is quite abit of restriction in the stock exhaust system so your sure to gain those extra rwkw's that your after.
If you want to know what Pineapples are read my review here
https://www.sau.com.au/forums/topic/9582-need-more-power/#findComment-146396
Thanks guys for all your help...if U think of anything else pls let me know...might go the 3" cat back jobbie for now - if there is a lot a restriction in the stock exh, then this might do the trick...
just as an estimate, how many rwkw's might I get just going cat back? If it's resonably quiet like U say, the gf shouldn't have noth'in to complain 'bout!!! - can someone recommend a good place to get this exh or price it??? - I've got a local guy, but don't know if he's on the money...what about nizpro in bayswater???
thanx.
https://www.sau.com.au/forums/topic/9582-need-more-power/#findComment-146422
I've got a mod that won't get you any power, but won't cost you a cent! What it will do though is allow further mod's down the track.......
It's called the no more g/f mod :wave: Sorry, couldn't help it!
https://www.sau.com.au/forums/topic/9582-need-more-power/#findComment-146918
Try around the local haunts and keep getting your car dynod at different places until you find one that reads high, and presto 170rwkws:D
Ive heard some people removing the wire mesh from their airflow meter for a few Kws, but power costs money even when you can do things yourself.
https://www.sau.com.au/forums/topic/9582-need-more-power/#findComment-146990
why don't you remove as much stuffs as you can out of your car ie lightened it?
spare tyres, sound system, air con, carpets, sound deadening etc...:D:)
and oh yeah lose some weight yourself, probably makes money out of the craps you took out of your car for more meaning mods.. :rolleyes:
just my 2c...
https://www.sau.com.au/forums/topic/9582-need-more-power/#findComment-147318
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
