where can i get gauges to fit in a slot where a head unit normally sits as i have an empty spot after installing my new stereo, or can ya get like a plastic holder tray thingy to just put small pieces of paper, a little mobile phone and other miscellaneous items as a small storage type thing, its just i dont want a gaping hole in my centre console :rolleyes: and if you can get this stuff, where and how much ?
have u ever seen the inside of a GTR before? u do realise that u can buy the 3 guage cluster that sits in there... probably expensive unless u can find one second hand at a decent rate. im sure if u hunt around u can find something
I've seen someone on SDU manage to squueze 3 52mm gauges in the centre bit under the stereo.
Looked great. It was a very very tight fit, and I think he had to angle the gauges towards the driver slightly to fit them in!!!!
The problem with getting the GTR center doova is that it goes right up the top where the air con is. It has that corner bit (top right) missing to fit in there, but so does the air con :D
So if you move the air con down, or put the GTR doova under the air con, the middle one will have the corner piece missing as well.....
Another thing about the GTR console is that it takes 42 or 45mm gauges, which are hard to find. And there's no use using the GTR gauges cause it has the 4wd gauge on it which will be usless on a GTS-t :)
J
also jsut wondering,i have a pioneer 6450 head unit that i just installed today and i mounted it with the two standard screw holes on the bracket, and its a good 2 cms in the dash so its ugly at the moment, whats the best way of bringing it forward to fit snugly to the front ?
Scotty - you can get 45mm gauges here
http://www.omorimeter.co.jp/english.html
Don't know if they are any good or not, plus you'll have to mod the plate a little to get them in.
Anyone else know where to get 43mm gauges??
J
Or you could try this:
*3 Gauges on top
*Air vents
*Climate Control
*A/M Single din stereo
*Centre-console-plastic-compartment-holder-thingy-doova-tray-box
*Cig lighter / ash tray...
Just an idea :wave:
ps. the tray fits a mobile / charger / handsfree or small sunnies, but probably not all at once :) [a single din-sized box]
i dont mind the original, its better than any other car i have seen, but until i come across one i like better im sticking with the original, but i know i do need a new boot for my handbrake and possibly even the gear knob as they are pretty ****ed :P
btw just successfully install my two front 6"ers yesterday i did the head unit and the amp in the bootr, now im off to bunnings to get some MDF to raise my 6x9s on the back aprc el shelf, not to mention carpet it, boy o boy this is gunna be a pretty big job :)
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
