  • Replies 183
A little under $6k got me:
STRIP & CLEAN 6 CYL TWIN CAM ENGINE
BORE & HONE 6 CYL ENGINE WITH TORQUE PLATE
MILL 6 CYL BLOCK
CHECK SIZE & POLISH 6 CYL CRANK
SUPPLY AND FIT SCREW IN OIL GALLERY PLUGS TO NISSAN L/RB/CA/SR CRANKSHAFT
CLOSE AND GRIND CONROD
PIN FIT ROD
SHOT PEEN CONROD SET
BALANCE 6 CYL ENGINE
FULL HEAD SERVICE
FULL GASKET SET- NISSAN RB25DET
COMETIC MLS HEAD GASKET
WISECO FORGED PISTON W/- RINGS
ARP ROD BOLT SET- RB30
CONROD BEARING SET- NISSAN RB30
MAIN BEARING SET- RB30
GATES RACING TIMING BELT
TIMING BELT TENSIONER
BLUEPRINT ASSEMBLE 6 CYL DOHC LONG ENGINE
SUPPLY MACHINE & FIT OIL PUMP DRIVE COLLAR- RB25/RB26
I supplied the cams and paid to transport the engine to and fro which wasn't much considering.
knore,
not that you are asking me but... When I had my motor built up it was sat on a pallet, strapped down and glad wrapped up.
Fork came along and dropped it on my trailer that had a nice thick rug on it so I was able to slide the pallet off.
Myself and my other half then slide the pallet off the trailer on to the ground using a few bits of wood.
Easy Peazy.
One of the SAU NSW club members helped me out with TNT to transport it.
Best to get your engine builder to book it on their account and then bill you, that way you get proper trade price.
I drove to an industrial area (not far for me) and looked around for a pallet of the right size (you want one about half or even less the normal size). It was easy, had plenty to choose from. Companies just stack them up near their rubbish bins.
I bought a twin pack of those snatch straps for about $10 and strapped the engine down tight.
Ok thanks, so you pulled engine out yourself, put it on a pallet, strapped it down and then got TNT to pick it up and deliver to proengines.
Then when it was done proengines got tnt to pick up and deliver back to you?
  • 10 months later...
It is about my rebuild but it was also supposed to be a repository for NEO info which it has turned out to be.
Shonen - you're obsessed with highmount. I'm more likely to put nos on it than a highmount. That said, a 2835ProS would be nice but I can't afford anything atm.
I've already got the highflow so I'm sticking with that due to $$. I've got some cams going in though so that should make some difference.
I think the 4 doors have the viscous LSD and the 2 doors get the helical LSD which means I'll be up for a new diff at some stage.
I was pretty sure all the turbo (2dr and 4dr) have the helical diff and only the autos have the viscous LSD's? Does anyone know this for sure?
Pete,
* The internal diameter of the stock GTT guage holes is 60mm
* Defi BF guages (amber or white dial) are only available in 60mm
Therefore the Defi BF (60mm) gauges will fit fine as you can see from the pics, but the bezel will be mounted outside the hole.
This pic shows Defi black 60mm gauges (not BF) fitted.
Not enough gauges here.... :ninja:
JustinP; you want ideas on how to install a e-01 in the R34? We've done two now (one on my one and one for a customer) and we concluded that there is only one spot for it... and that's in front of the centre vents.
Custom bracket needed to be made...
Yep any ideas would be great :)
I was thinking of removing the ashtray, bolting in a bracket inside, and mounting it as low as possible there. I figure it will cover some of the double DIN stereo but don't mind. Think this would be possible? My gf said she would rather if I didn't cover the vents heheh
I don't actually have the E-01 yet so I haven't got a real idea on the size of unit yet, I guess I should check the specs on it.
Well the way I've done it is actually just using an upside down L bracket which "hooks" onto the air vents...
1) It's removable for security
2) It looks neat
3) You don't have to look all over the place whilst driving
4) The rather intrusive wiring can be run into the vents
5) Ventilation keeps the unit "cool"
6) Keeps double din area completely clear
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
