  • Replies 183
So you guys really rate the GCG hi-flow as the best option for the 34GTT?  I have an auto as well and probably chasing 250rwkw for the time being.  How much extra kw will this turbo give just by itself :D  I'm currently on about 200 so I don't know.  If it's a long way off, I might as well get a different turbo.
We rate it as a good comprimise. An upgraded turbo needs supporting mods like injectors, fuel pump etc. to be used properly.
Pick a power figure then pick a turbo to suit. You don't want 250rwkw with a 2835ProS because you are wasting the turbos top end and therefore introducing needless lag. But if you can get 250 with a GCG highflow without getting out of its efficiency zone then you have chosen the right turbo for your required power. (And saved yourself a big pile of money in the process:D)
Search!!!
Since i searched this to death recently... :
without cams most are getting 230-250rwkw, mostly 240-250, some are around 220-230 (and seem to have been a little disappointed)
with cams up to 265 eg SK's cars
I spent a lot of time trying to compare GCG hiflows Vs HKS GT-RS, but i can't find many power figures for the HKS item :( they seem fairly similar though...
Edited by Beeble
All the information you guys need is already on here.
For a GT-RS or GCG highflow you will need injectors, fuel pump, probably a fuel regulator, full exhaust, high flow panel filter or pod in a box, some sort of engine management and modification or replacement of the AFM to turbo pipe which will suck closed at this power level.
A GT-RS is a slight step up from the GCG HF. People have achieved 300rwkw with cams. If you high flow an R33 turbo you will not get as much power as a highflow of the R34 turbo as the exhaust housing is bigger on the R34. An alternative is to put a VG30 rear housing on the R33 turbo.
I've got 480cc Nismo injectors. I don't know/remember what Bass Junky has used. Also, did you go to Z32 AFM Bass?
i had my car dyno'd the other day as i had a ebc fitted to stop rich retard or boost cut or whatever it was. With stock computer and boosted to 10psi i only pulled 160rwkw. I have blitz lm fmic 3" exhaust filter. That seems a little low what do you guys think. Its and auto r34 by the way.
Bass,
Id like to compare your car to mine as i pulled 244 rwkw in my R33 HKS 2535 on 14psi (no cams), on the Racepace dyno.
It would be interesting to see how they compare!
Can i race the winner, ive got a 2535 and only pushed 231rwkw.
thanks bass.
was that with same mods as me? ie I/C exhaust?
i have bought emanage ultimate and am waiting for an ignition signal adaptor to come so i can fit it. I wonder how much more power i get. How much did you get with computer?
SK's 265rwkw figure was recorded in Shootout mode which at 250rwkw reportedly gives about 10-15 rwkw higher figure.
Quick clarificatin, we have been able to duplicate the 265 rwkw (+ or - a couple of rwkw) in non Shoot Out mode. Several times during winter with ambient temperatures in the mid teens and inlet (to the filter) temps just under 20 degrees.
It is one of the reasons why I can confidently say that Shoot Out mode doesn't ALWAYS give higher power readings. Well, not on our dyno anyway.
:( cheers :(
What is the most power you can get out of a GCG hi-flow with all supporting mods on an R33 GTS-T manual?
We have seen an R34GTT (R34GTT turbine housing) with 275 rwkw. That's on Sydney Optimax. If I remember rightly Bullant (Ian) acheived similar with his R33GTST using a VG30 turbine housing. Using Elf TurboMax I have seen 310 rwkw.
:( cheers :(
Edited by Sydneykid
OK so a GCG hi-flow would be good for up to about 250rwkw... after a decent tune. I'm assuming that the SAFCII won't be good enough for tuning purposes?
So for all supporting mods:
1 x hi flo turbo or similiar
1 x new fuel pump
1 x adjustable fule reg
1 x new management system???
Would you guys reccomend getting new injectors or would the R34 stock injectors be good for 250rwkw?
Stan
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
