Hi Guys, well what a pain in the arse that was... Just fitted my 'D1' aluminimum intercooler piping to my china copy front mount. Things just don't line up as they should and it doesn't sit exactly straight (but I can deal with that later, lets get to the real issue).
After fitting it all (what a pain in the arse that was) I ticked it over and gave it a rev not noticing anything strange but with my blitz BOV in one hand and the throttle in the other I put 2 and 2 together! (Why is it still shooshing??) :)
I noted it was coming from the air pod and figured it was venting from the factory plumb back, through the turbo and back through the filter?
My question... Is this normal and has anyone else experenced it and if not, whats the problem?
Also, it is not as loud when driving and definatly not as loud as with the blitz.
Thanks all,
Todd
https://www.sau.com.au/forums/topic/95876-installed-fmic-and-removed-bov/
YAY! Thanks mate! Now I can sell my valve... he he he
To be honest, I was very surprised with the difference. I am running 12psi and it seems to get there quicker and stay there!
Mose people report a loss or no improvement but I must say it is alot better and I only have 3" exhaust, cheap pod filter and boost controller along with an engine that needs a good service.
Also, can anyone tell me while I am at it why in second gear it coughs a bit when getting on boost (not all the time)... I know I need to give it a service (haven't done one since it got here - only been 2 weeks but I know it is a big no no)...
I am guessing with a new set of plugs and some fresh oil it will be right! I need the timing belt done too, how much should I expect to pay someone else to do it for (looks like too much of a pain to do myself)...
Thanks guys!
Todd
This is normal :)
Edited by CATKICKER
a fair workshop will charge u 280 for a timing belt replacement including coolant etc
anymore more than say 330 is a rip off.
it probably needs a good service along with spark plugs , fuel filter, etc thats what could be causing the hesitation in second gear.
Fit a cold air intake using one of your old intercooler pipes thru the spare hole below your pod filter and get a shield for the pod filter u will really notice the difference. also with the repco "monza" heat shield my pod now emits a "wtt-oosh"
i guess the air bouncing off the shield :)
Thanks a lot guys!
I will have to get the belt done and I will as you suggest give it a full service including engine oil, oil filter, gearbox oil, fuel filter and plugs.
When I get the belt done is there any special timing I should get it set to? And when buying the oil/plugs, are there any particular items that work best in an RB20?
Thanks!
Todd
i guess the air bouncing off the shield  :D
my car makes that noise(RB25) with fmic cat back pod, but iv bn told and also read in fast fours that if your running more than stock boost it can be harmful to your turbo....there was a thread about this last week also......
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
